1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: IR cameras
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "Wang, SuYin Grass" <grass at anl.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 24 Mar 2026 19:15:20 +0000
Hi Grass,
Actually the last 2 cameras do also list GigE vision in both their main Web page and in the datasheet.  So it seems like any of them should work.
Sent: Tuesday, March 24, 2026 1:50 PM
To: Mark Rivers <rivers at cars.uchicago.edu>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Here is a list of IR cameras that list GenICam and GigE Vision in their specifications
Flir A50 and A70
FLIR Axxx-Series Image Streaming
FLIR A615
There are also two that may not work because they only list GenICam, but GigE Vision is not listed
Flir A6481
Flir A6451
Sent: Tuesday, March 24, 2026 1:44 PM
To: Wang, SuYin Grass <grass at anl.gov>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
I noticed that the newer FLIR thermal cameras list support for both GenICam and GigE Vision. Does support for GenICam and GigE Vision generally mean that these cameras are likely to be compatible with ADAravis and ADGenICam? Yes, they should
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
  • I noticed that the newer FLIR thermal cameras list support for both GenICam and GigE Vision. Does support for GenICam and GigE Vision generally mean that these cameras are likely to be compatible with ADAravis and ADGenICam?
Yes, they should work with ADAravis.  Can you send me a link to one of the newer FLIR thermal cameras you are considering?
Sent: Tuesday, March 24, 2026 1:13 PM
Thank you for the suggestion.
After installing ADURL, I found that it can repeatedly read an image from a fixed URL. However, this does not seem to work well for the AX8.
The AX8 does not continuously save the JPG file, so the image still has to be saved manually. Also, when I try to use the URL provided by the web interface, it downloads an HTML file rather than a JPG image:
test.jpg: HTML document, UTF-8 Unicode text
This causes an error in the IOC:
URLDriver:readImage: error reading URL="" No decode delegate for this image format (/tmp/gmh3AIyd) reported by ../constitute.c:1535 (GmReadImage)
Even if the URL issue can be addressed, we may still need a more suitable solution for data collection.
Flir A35 works with ADAravis and ADGenICam, but it is discontinued.
Thank you!
Grass
Sent: Monday, February 23, 2026 10:23 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>; Wang, SuYin Grass <grass at anl.gov>
Hi Grass, I looked at the specifications for the FLIR AX8 here: https: //www. flir. com/products/ax8-automation/?srsltid=AfmBOopZ0uYNLWFDaFGoK4C9KUp2GAC18Z8G326QffsMsXn-A2gF3mXQ It says that the camera can stream images in Motion JPEG, MPEG, and
Hi Grass,
It says that the camera can stream images in Motion JPEG, MPEG, and H.264 formats.  That suggests that you may be able to use ADURL, which works for reading from URLs in formats that include JPEG.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Wang, SuYin Grass via Tech-talk <tech-talk at aps.anl.gov>
Sent: Monday, February 23, 2026 8:48 AM
Subject: IR cameras
We currently have an FLIR AX8 and an Optris PI-1M. Does anyone have the  EPICS support for it already?
The FLIR AX8 doesn’t support Aravis, so ADAravis won’t work.
Are there recommended IR cameras that integrate well with EPICS (ideally via an existing areaDetector driver)?
Thank you!
Grass
IR cameras Wang, SuYin Grass via Tech-talk
Re: IR cameras Mark Rivers via Tech-talk
Re: IR cameras Wang, SuYin Grass via Tech-talk
Prev: Re: IR cameras Wang, SuYin Grass via Tech-talk
Next: Re: Lack of error message from invalid CROSS_COMPILER_TARGET_ARCHS Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: Help in debugging ACF connection issue Érico Nogueira Rolim via Tech-talk
ANJ, 24 Mar 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
