1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: IOC showing out errors in call SNMP functions on linux-x86_64
From: "Hu, Yong via Tech-talk" <tech-talk at aps.anl.gov>
To: "Priller, John" <priller at frib.msu.edu>, Varuna Crishan Meddage <vmeddage at fnal.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 25 Feb 2026 22:23:49 +0000
Hi Varuna,
Additional to John’s suggestion of verifying your ‘WRSwitch.dbd’, you can do a few more checks:
  1. Your SNMP support module is located at /usr/local/epics/Support/snmp. You are using WRSwitch_LIBS += devSnmp and WRSwitch_DBD += devSnmp.dbd. Do you see the SNMP support library files generated? i.e. /usr/local/epics/Support/snmp/lib/linux-x86_64/libdevSnmp.so (.a)?
  2. Check your IOC’s binary by the command ldd (or the command strings) and you should see something related to SNMP: ldd /export/home1/vmeddage/WRSwitch/bin/linux-x86_64/WRSwitch | grep -i snmp
HTH,
Yong
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Priller, John via Tech-talk <tech-talk at aps.anl.gov>
Date: Tuesday, February 24, 2026 at 1:01 PM
What is the content of your file here:
/export/home1/vmeddage/WRSwitch/iocTops/WRSwitch/dbd/WRSwitch.dbd
When I 'grep -i snmp' on one of mine, it gives:
device(longin, INST_IO, devSnmpLi, "Snmp")
device(ai, INST_IO, devSnmpAi, "Snmp")
device(ao, INST_IO, devSnmpAo, "Snmp")
device(longout, INST_IO, devSnmpLo, "Snmp")
device(waveform, INST_IO, devSnmpWf, "Snmp")
device(stringin, INST_IO, devSnmpSi, "Snmp")
device(stringout, INST_IO, devSnmpSo, "Snmp")
registrar(snmp_Register)
The final registrar line is what provides the devSnmpXxx commands to IOC shell.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Varuna Crishan Meddage via Tech-talk <tech-talk at aps.anl.gov>
Sent: Tuesday, February 24, 2026 12:47 PM
To: tech-talk at aps.anl.gov
Subject: IOC showing out errors in call SNMP functions on linux-x86_64
My EPICS IOC call SNMP specific functions (devSnmpSetSnmpVersion, devSnmpSetParam).
When I run my IOC these function calls throw out errors saying (Command devSnmpSetSnmpVersion not found.)
In my Makefile at App/src area, I am calling the support snmp library and dbd file correctly.
Any help to solve this issue ?
(Here I am pasting output of after running st.cmd,  Makefile at App/src are,  content of Release.local file,  content of st.cmd file at iocBoot area)
******************************************* START OF OUTPUT AFTER RUNNING ST.CMD FILE ***************************************************
iocdev1$ ./startWRSwitch.bash
#!../../bin/linux-x86_64/WRSwitch
< envPaths
epicsEnvSet("IOC","iocWRSwitch")
epicsEnvSet("TOP","/export/home1/vmeddage/WRSwitch/iocTops/WRSwitch")
epicsEnvSet("MODULES","/export/home1/vmeddage/WRSwitch/iocTops")
epicsEnvSet("EPICS_BASE","/usr/local/epics/base")
epicsEnvSet("SUPPORT","/usr/local/epics/Support")
epicsEnvSet("SNCSEQ","/usr/local/epics/Support/seq")
epicsEnvSet("ASYN","/usr/local/epics/Support/asyn")
epicsEnvSet("IPAC","/usr/local/epics/Support/ipac")
epicsEnvSet("CALC","/usr/local/epics/Support/calc")
epicsEnvSet("STD","/usr/local/epics/Support/std")
epicsEnvSet("SSCAN","/usr/local/epics/Support/sscan")
epicsEnvSet("STREAM","/usr/local/epics/Support/StreamDevice")
epicsEnvSet("BUSY","/usr/local/epics/Support/busy")
epicsEnvSet("IOCSTATS","/usr/local/epics/Support/iocStats")
epicsEnvSet("LINSTAT","/usr/local/epics/Support/linStat")
epicsEnvSet("LUA","/usr/local/epics/Support/lua")
epicsEnvSet("PCRE","/usr/local/epics/Support/pcre")
epicsEnvSet("SNMP","/usr/local/epics/Support/snmp")
epicsEnvSet("ACNETPV","/usr/local/epics/Support/acnetPV")
epicsEnvSet("ALIVE","/usr/local/epics/Support/alive")
epicsEnvSet("TCAST","/usr/local/epics/Support/tcast")
epicsEnvSet("RECASTER","/usr/local/epics/Support/RecCaster")
epicsEnvSet("AUTOSAVE","/usr/local/epics/Support/autosave")
epicsEnvSet("PUTLOG","/usr/local/epics/Support/caPutLog")
## NTP Time Synchronisation
#epicsEnvSet("EPICS_TS_NTP_INET","131.225.121.105")
## Do OS-specific startup here
epicsEnvSet("EPICS_HOST_ARCH","linux-x86_64")
epicsEnvSet("ENGINEER","vmeddage")
epicsEnvSet("LOCATION","BTE-223")
epicsEnvSet("EPICS_IOC_OWNER","vmeddage")
epicsEnvSet("EPICS_IOC_GROUP","FE_group")
epicsEnvSet("EPICS_IOC_LOCATION","BTE-223")
epicsEnvSet("IOCDIR","WRSwitch")
epicsEnvSet("MIBDIRS","+/export/home1/vmeddage/.snmp/mibs")
cd "/export/home1/vmeddage/WRSwitch/iocTops/WRSwitch"
# Load SNMP support database
dbLoadDatabase("/export/home1/vmeddage/WRSwitch/iocTops/WRSwitch/dbd/WRSwitch.dbd",0,0)
WRSwitch_registerRecordDeviceDriver(pdbbase)
INFO: PVXS QSRV2 is loaded, permitted, and ENABLED.
2026-02-24T11:42:03.147799408 WARN pvxs.tcp.setup Server unable to bind port 5075, falling back to [::]:35161
dbRegisterServer: Ignoring 'rsrv', per environment
## SNMP specifics
devSnmpSetSnmpVersion(10.200.34.10,SNMP_VERSION_2C)
ERROR st.cmd line 29: Command devSnmpSetSnmpVersion not found.
devSnmpSetParam("DebugLevel",2)
ERROR st.cmd line 31: Command devSnmpSetParam not found.
devSnmpSetParam("SessionTimeout", "1000000")
ERROR st.cmd line 32: Command devSnmpSetParam not found.
## Protocal file
#epicsEnvSet("STREAM_PROTOCOL_PATH","/usr/local/epics/Support/cmsIon/cmsIonApp/protocol")
## Load record instances
#dbLoadRecords("${EPICS_IOCTOPS}/${IOCDIR}/db/WRSwitchalive.db")
#dbLoadRecords("${EPICS_IOCTOPS}/${IOCDIR}/db/WRSwitchwatcher.db")
#dbLoadRecords("${EPICS_IOCTOPS}/${IOCDIR}/db/WRSwitchiocAdminSoft.db")
#dbLoadRecords("${EPICS_IOCTOPS}/${IOCDIR}/db/WRSwitchAcnetDevice.db")
#dbLoadRecords("${EPICS_IOCTOPS}/${IOCDIR}/db/WRSwitchExtra.db")
#dbLoadRecords("${EPICS_IOCTOPS}/${IOCDIR}/db/WRSwitchtcast.db")
#dbLoadRecords("${EPICS_IOCTOPS}/${IOCDIR}/db/WRSwitchRecCaster.db")
#dbLoadRecords("${EPICS_IOCTOPS}/${IOCDIR}/db/test.db")
dbLoadTemplate("/export/home1/vmeddage/WRSwitch/iocTops/WRSwitch/db/wrz16_pip2_switch.substitution")
## Put logging and access security
epicsEnvSet("EPICS_CA_JSON_PUT_LOG_ADDR","/home/epics/epicsDEV/PutLog/test.json")
asSetFilename("/export/home1/vmeddage/WRSwitch/iocTops/WRSwitch/iocBoot/iocWRSwitch/ioc.acf")
iocInit()
Starting iocInit
## EPICS R7.0.9
## Rev. R7.0.9-dirty
## Rev. Date Git: 2025-02-21 17:31:33 -0600
caPutJsonLogInit localhost:7011
## Create as many matching Acnet devices as needed and uncomment
#createAcnetDeviceRecord Z:WRSwitchCRTL
dbpf PIP2:Time_CRTL_SYS:alive.EV1 linux-x86_64
PV 'PIP2:Time_CRTL_SYS:alive.EV1' not found
dbpf PIP2:Time_CRTL_SYS:alive.EV2 7.0.9
PV 'PIP2:Time_CRTL_SYS:alive.EV2' not found
dbpf PIP2:Time_CRTL_SYS:alive.EV3 /usr/local/epics/base
PV 'PIP2:Time_CRTL_SYS:alive.EV3' not found
dbpf PIP2:Time_CRTL_SYS:alive.EV4 /usr/local/epics/Support
PV 'PIP2:Time_CRTL_SYS:alive.EV4' not found
dbpf PIP2:Time_CRTL_SYS:alive.EV5 vmeddage
PV 'PIP2:Time_CRTL_SYS:alive.EV5' not found
log client: failed to connect to server '127.0.0.1:7011' because 'Connection refused'
dbpf PIP2:Time_CRTL_SYS:alive.EV6 BTE-223
PV 'PIP2:Time_CRTL_SYS:alive.EV6' not found
dbpf PIP2:Time_CRTL_SYS:alive.EV7 "Front Ends"
PV 'PIP2:Time_CRTL_SYS:alive.EV7' not found
****************************************** END OF OUTPUT AFTER RUNNING ST.CMD FILE ************************************************
********************************************** START OF MAKE FILE ***********************************************************************
TOP=../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
# Build an IOC support library
#LIBRARY_IOC += devSnmpLocal
#devSnmpLocal_SRCS += $(SNMP)/snmpApp/src/snmpRegister.cpp
#devSnmpLocal_SRCS += $(SNMP)/snmpApp/src/snmpSessShow.c
#devSnmpLocal_SRCS += $(SNMP)/snmpApp/src/devSnmp.cpp
#devSnmpLocal_LIBS += $(EPICS_BASE_IOC_LIBS)
# Build the IOC application
PROD_IOC = WRSwitch
# WRSwitch.dbd will be created and installed
DBD += WRSwitch.dbd
# WRSwitch.dbd will be made up from these files:
WRSwitch_DBD += base.dbd
# modified menuScan.dbd to include FNAL scan rates
WRSwitch_DBD += menuScan.dbd
# Include dbd files from all support applications:
WRSwitch_DBD += pvxsIoc.dbd
WRSwitch_DBD += iocAdmin.dbd
WRSwitch_DBD += aliveRecord.dbd
WRSwitch_DBD += sseqRecord.dbd
WRSwitch_DBD += sscanSupport.dbd
WRSwitch_DBD += acnetPV.dbd
WRSwitch_DBD += tcast.dbd
WRSwitch_DBD += reccaster.dbd
WRSwitch_DBD += asSupport.dbd
WRSwitch_DBD += caPutJsonLog.dbd
# Add all the support libraries needed by this IOC
WRSwitch_LIBS += devIocStats
WRSwitch_LIBS += alive
WRSwitch_LIBS += acnetPV
WRSwitch_LIBS += calc
WRSwitch_LIBS += pv seq
WRSwitch_LIBS += sscan
WRSwitch_LIBS += tcast
WRSwitch_LIBS += reccaster
WRSwitch_LIBS += autosave
WRSwitch_LIBS += caPutLog
WRSwitch_LIBS += pvxsIoc pvxs
# WRSwitch_registerRecordDeviceDriver.cpp derives from WRSwitch.dbd
WRSwitch_SRCS += WRSwitch_registerRecordDeviceDriver.cpp
WRSwitch_SRCS += CopyArray.c
# Build the main IOC entry point on workstation OSs.
WRSwitch_SRCS_DEFAULT += WRSwitchMain.cpp
WRSwitch_SRCS_vxWorks += -nil-
# Add header files:
#USR_INCLUDES += -I/usr/include
# Finally link to the EPICS Base libraries
WRSwitch_LIBS += $(EPICS_BASE_PVA_CORE_LIBS) # Added by Varuna
WRSwitch_LIBS += nt pvaClient pvDatabase # Added by Varuna
WRSwitch_LIBS += $(EPICS_BASE_IOC_LIBS)
#USR_CFLAGS += `net-snmp-config --cflags`   # W.T.
#USR_CPPFLAGS += `net-snmp-config --cflags` # W.T.
#USR_CFLAGS += -DNETSNMP_NO_INLINE
#USR_LDFLAGS += `net-snmp-config --libs` # W.T.
#PROD_LDLIBS += `net-snmp-config --libs` # W.T.
#USR_CFLAGS += -fPIE
#USR_CPPFLAGS += -fPIE
USR_CFLAGS += -fPIE
#USR_CFLAGS += $(shell $(PERL) $(SNMP)/snmpApp/src/getNetSNMPversion.pl) # Added by Varuna
#USR_CPPFLAGS += $(shell $(PERL) $(SNMP)/snmpApp/src/getNetSNMPversion.pl) # Added by Varuna
USR_CXXFLAGS_DEFAULT += -fno-operator-names -pedantic
USR_CXXFLAGS += -W -Wall
USR_CXXFLAGS += -fPIE
include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
#USR_CXXFLAGS_DEFAULT += -fno-operator-names -pedantic
#USR_CXXFLAGS += -W -Wall
*********************************************************************** END OF MAKE FILE *********************************************
In my RELEASE.local file I am specifying the correct location of snmp directory as well.
*********************** START of RELEASE.LOCAL FILE *********************************************
EPICS_BASE=/usr/local/epics/base
SUPPORT=/usr/local/epics/Support
SNCSEQ=$(SUPPORT)/seq
ASYN=$(SUPPORT)/asyn
IPAC=$(SUPPORT)/ipac
CALC=$(SUPPORT)/calc
STD=$(SUPPORT)/std
SSCAN=$(SUPPORT)/sscan
STREAM=$(SUPPORT)/StreamDevice
BUSY=$(SUPPORT)/busy
IOCSTATS=$(SUPPORT)/iocStats
LINSTAT=$(SUPPORT)/linStat
LUA=$(SUPPORT)/lua
PCRE=$(SUPPORT)/pcre
SNMP=$(SUPPORT)/snmp
ACNETPV=$(SUPPORT)/acnetPV
ALIVE=$(SUPPORT)/alive
TCAST=$(SUPPORT)/tcast
RECASTER=$(SUPPORT)/RecCaster
AUTOSAVE=$(SUPPORT)/autosave
PUTLOG=$(SUPPORT)/caPutLog
******************************************* END OF RELEASE.LOCAL FILE ****************************
**********************************. START OF ST.CMD FILE **********************************************
#- You may have to change WRSwitch to something else
#- everywhere it appears in this file
< envPaths
epicsEnvSet("ENGINEER","$(ENGINEER=vmeddage)")
epicsEnvSet("LOCATION","$(LOCATION=BTE-223)")
cd "${TOP}"
dbLoadDatabase("${EPICS_IOCTOPS}/${IOCDIR}/dbd/WRSwitch.dbd",0,0)
## SNMP specifics
## Protocal file
dbLoadTemplate("${EPICS_IOCTOPS}/${IOCDIR}/db/wrz16_pip2_switch.substitution")
asSetFilename("${EPICS_IOCTOPS}/${IOCDIR}/iocBoot/ioc${IOCDIR}/ioc.acf")
iocInit()
dbpf PIP2:Time_CRTL_SYS:alive.EV1 ${ARCH}
dbpf PIP2:Time_CRTL_SYS:alive.EV2 ${EPICS_VERSION_SHORT}
dbpf PIP2:Time_CRTL_SYS:alive.EV3 ${EPICS_BASE}
dbpf PIP2:Time_CRTL_SYS:alive.EV4 ${EPICS_SUPPORT}
*************************************************** END OF ST.CMD FILE *********************************************
IOC showing out errors in call SNMP functions on linux-x86_64 Varuna Crishan Meddage via Tech-talk
Re: IOC showing out errors in call SNMP functions on linux-x86_64 Priller, John via Tech-talk
Prev: Moving NSCL/FRIB's SNMP driver to epics-modules Henrique F. Simoes via Tech-talk
Next: FW: IOC showing out errors in call SNMP functions on linux-x86_64 Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: External: Re: IOC showing out errors in call SNMP functions on linux-x86_64 Varuna Crishan Meddage via Tech-talk
