1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: CA gateway crashes periodically due to badly behaved servers
From: Brian Bevins via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Sat, 7 Mar 2026 20:50:13 +0000
I've noticed an odd behavior in one of our channel access gateways. We use them in various places to sort of shield our stuff from stuff we don't control. I'm using version 2.1.3.
There is an apparently badly behaved server that I don't control that is seen by the gateway. It's a bit of a black box even to those who do control it. All I know is that it's a pxi crate running a LabView ca server. It disconnects about once every 8-40 seconds and frequently returns errors about bad resource IDs, apparently in response to CA_PROTO_EVENT_CANCEL commands. For unknown reasons this happens much more often than it did when we were running version 2.0.3.0 of the gateway. I'm still looking into that.
The gateway does a fine job of ignoring the errors and reconnecting, until it has received 100 errors. After that the error logging throttle kicks in and it logs only disconnects for 1 hour. What seems odd to me is that when it does this it uninstalls its own error handler. When the next serious error comes in it invokes the default client handler and aborts the program. This seems wrong to me. I've worked around it by just not uninstalling the error handler. Messages still stop being logged for an hour, but they don't abort the gateway.
The gateway always restarts within just a few seconds, but our archiver (Mya) doesn't always reconnect for some reason, leaving occasional gaps of several hours in the archived data. I'm trying to look into this too. Unfortunately  our Mya expert just retired.
--Brian Bevins
   Thomas Jefferson National Accelerator Facility
Re: CA gateway crashes periodically due to badly behaved servers Wang, Lin via Tech-talk
Re: CA gateway crashes periodically due to badly behaved servers Williams Jr., Ernest L. via Tech-talk
Prev: Re: Help in debugging ACF connection issue Hu, Yong via Tech-talk
Next: Re: CA gateway crashes periodically due to badly behaved servers Wang, Lin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Prev: p4p helper module for device support development Sukhanov, Andrei via Tech-talk
