Hello Brian, At CSNS, we have been using LabView IOCs in beam diagnostic devices together with CA gateway for quite a few years, it seems that CA gateway is sensitive with unexpected data format and it indeed sometimes crashes or stops working even if not crashes. We plan to replace the non-standard IOCs in the ongoing CSNS upgrade. But the intelligent aspect of CA gateway or the depending ca library in EPICS base is that they always reports the specific bad format PVs in the log file for us to troubleshoot. For example, half a year ago, we encountered a similar issue that the CA gateway serving LabView IOCs keep restarting until crash when bad format PVs are being accessed by other CA clients via the CA gateway, reported like this in the CA gateway log file: Oct 03 00:21:54 !!! Errlog message received (message is above) filename="../../../../src/cas/generic/casPVI.cc" line number=253 Bad data type application type "enums" string conversion table for enumerated PV isnt a string type? Then, we added one line in EPICS base to print (the print feature exists in newer EPICS version by default) the problematic PVs and reported the issue to colleagues in the beam diagnostic group, they restarted the relevant IOC to resolve the issue and it never happens again. So, when issue occurs in our LavView IOC / CA gateway environment, we often restart CA gateway, or find the problematic IOC and restart the IOC. Regards, Lin -----Original Messages-----
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
