1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: [EXTERNAL] Re: CA gateway crashes periodically due to badly behaved servers
From: Brian Bevins via Tech-talk <tech-talk at aps.anl.gov>
To: "Wang, Lin" <wanglin at ihep.ac.cn>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 12 Mar 2026 16:44:44 +0000
HI Lin,
Thank you for the information. In my case I don't seem to get back the name of the PV in question. The server reports that the exception was generated in response to cancelling a subscription, but the payload doesn't include the PV name.
I can report that the problem does seem to be mitigated now that I've tweaked our gateway to not uninstall it's exception handler when the throttle trigger is reached. The gateway just keeps running. It still disconnects from the Labview server much more frequently than our older gateway (2.0.3) did. I'm not sure why yet.
Best,
-Brian
Sent: Saturday, March 7, 2026 8:33 PM
To: Brian Bevins <bevins at jlab.org>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] Re: CA gateway crashes periodically due to badly behaved servers
Hello Brian,
At CSNS, we have been using LabView IOCs in beam diagnostic devices together with CA gateway for quite a few years, it seems that CA gateway is sensitive with unexpected data format and it indeed sometimes crashes or stops working even if not crashes. We plan to replace the non-standard IOCs in the ongoing CSNS upgrade.
But the intelligent aspect of CA gateway or the depending ca library in EPICS base is that they always reports the specific bad format PVs in the log file for us to troubleshoot.
For example, half a year ago, we encountered a similar issue that the CA gateway serving LabView IOCs keep restarting until crash when bad format PVs are being accessed by other CA clients via the CA gateway, reported like this in the CA gateway log file:
Oct 03 00:21:54 !!! Errlog message received (message is above)
filename="../../../../src/cas/generic/casPVI.cc" line number=253
Bad data type application type "enums" string conversion table for enumerated PV isnt a string type?
Then, we added one line in EPICS base to print (the print feature exists in newer EPICS version by default) the problematic PVs and reported the issue to colleagues in the beam diagnostic group, they restarted the relevant IOC to resolve the issue and it never happens again.
So, when issue occurs in our LavView IOC / CA gateway environment, we often restart CA gateway, or find the problematic IOC and restart the IOC.
Lin
-----Original Messages-----
From: "Brian Bevins via Tech-talk" <tech-talk at aps.anl.gov>
Send time: Sunday, 03/08/2026 04:50:13
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Subject: [SPAM] CA gateway crashes periodically due to badly behaved servers
I've noticed an odd behavior in one of our channel access gateways. We use them in various places to sort of shield our stuff from stuff we don't control. I'm using version 2.1.3.
There is an apparently badly behaved server that I don't control that is seen by the gateway. It's a bit of a black box even to those who do control it. All I know is that it's a pxi crate running a LabView ca server. It disconnects about once every 8-40 seconds and frequently returns errors about bad resource IDs, apparently in response to CA_PROTO_EVENT_CANCEL commands. For unknown reasons this happens much more often than it did when we were running version 2.0.3.0 of the gateway. I'm still looking into that.
The gateway does a fine job of ignoring the errors and reconnecting, until it has received 100 errors. After that the error logging throttle kicks in and it logs only disconnects for 1 hour. What seems odd to me is that when it does this it uninstalls its own error handler. When the next serious error comes in it invokes the default client handler and aborts the program. This seems wrong to me. I've worked around it by just not uninstalling the error handler. Messages still stop being logged for an hour, but they don't abort the gateway.
The gateway always restarts within just a few seconds, but our archiver (Mya) doesn't always reconnect for some reason, leaving occasional gaps of several hours in the archived data. I'm trying to look into this too. Unfortunately  our Mya expert just retired.
--Brian Bevins
   Thomas Jefferson National Accelerator Facility
Re: [EXTERNAL] Re: CA gateway crashes periodically due to badly behaved servers Brian Bevins via Tech-talk
Re: CA gateway crashes periodically due to badly behaved servers Wang, Lin via Tech-talk
Prev: Re: E3 conda build problem Anders Lindh Olsson via Tech-talk
Next: Re: CA gateway crashes periodically due to badly behaved servers Brian Bevins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: CA gateway crashes periodically due to badly behaved servers Wang, Lin via Tech-talk
Next: Re: [EXTERNAL] Re: CA gateway crashes periodically due to badly behaved servers Brian Bevins via Tech-talk
ANJ, 24 Mar 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
