Hi tech-talkers,
in using QSRV2 from pvxs I encountered several unexpected (for me) differences between pvget and pvxget.
I created a pva group in an IOC database as an NTTable. I'll use the example from the PVXS documentation as a minimal example (see here: https://epics-base.github.io/pvxs/qgroup.html#database-listing).
I used EPICS Base 7.0.10 and PVXS 1.5.1 to create a minimal IOC, with only base and pvxs.
I want to read only a single column from the table like:
pvxget -r "value.A" TST:Tbl
This works with pvxget, but not with pvget. Using pvget I simply get:
TST:Tbl <undefined>
A B
Is that expected behavior, did I miss some configuration or this a bug? If it is a bug, where should this be raised first?
Less critical, when constructing more complex requests, like selecting multiple columns from a single table, the syntax between the two differs. Is that intended?
For example:
pvget -r "field(value{LMT_l,LTM_h}) BPMZ1D1R:signals:sa:pva
works, same thing with pvxget gives me "Error: invalid character near: {LMT_l,LTM_h})"
Conversely, a working request for pvxget is
pvxget -r "field(value.LMT_l,value.LTM_h)" BPMZ1D1R:signals:sa:pva
When doing the same with pvget, it complains: "failed to parse request string: Can't construct Structure, duplicate fieldName value"
I was under the impression that pvxs is the more forward-looking implementation and one could/should use it in an IOC. While for the command line tools pvAccessCPP is the recommend way (at least it says so in the pvxs documentation). How are others handling this and what could I do to resolve these issues?
Cheers,
Malte
Dr. Malte Gotz
Phone: +49 030 8062 15808
Accelerator Operation - Control System Group
(BE-IA-AOT/ACS)
Aufsichtsrat: Vorsitzender Michael Zimmermann, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech, Saskia Vormfelde
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
