1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Re: pvget, pvxget and pvxs interoperability and differences
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: "Gotz, Malte" <malte.gotz at helmholtz-berlin.de>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 11 Mar 2026 07:53:29 -0700
Hello Malte,
PVXS has so far a simpler understanding of the pvRequest "friendly" text representation.  To be honest, you are the first person I know of who uses more than the simplest features of this syntax.  So thank you for this feedback.
Client API users can skip the text representation, and provide the equivalent data structure directly.  Of course, this does not help the CLI tools.
While it has been some time since I last looked into this aspect in detail, I recall that the pvRequest "language" was not formally specified.  I found the original hand coded parser hard to follow, and so did not try to reverse engineer it fully.  I would certainly like to see a proper grammar specification for the pvRequest text representation (EBNF or equivalent) as a starting point to change this.
Overall the CLI tools for PVXS have lagged behind more than I might have wished.  pvxget and friends have so far not been a priority for me, or anyone else.  So I will give the usual plea about welcoming contributions.  There are some PRs and issues open.  I'm sorry.  This is not the answer I would like to give, but this is the current situation.
https://github.com/epics-base/pvxs/issues/44
https://github.com/epics-base/pvxs/issues/66
https://github.com/epics-base/pvxs/pull/78
https://github.com/epics-base/pvxs/pull/63
On 3/11/26 4:33 AM, Gotz, Malte via Tech-talk wrote:
Hi tech-talkers,
in using QSRV2 from pvxs I encountered several unexpected (for me) differences between pvget and pvxget.
I created a pva group in an IOC database as an NTTable. I'll use the example from the PVXS documentation as a minimal example (see here: https://epics-base.github.io/pvxs/qgroup.html#database-listing).
I used EPICS Base 7.0.10 and PVXS 1.5.1 to create a minimal IOC, with only base and pvxs.
I want to read only a single column from the table like:
pvxget -r "value.A" TST:Tbl
This works with pvxget, but not with pvget. Using pvget I simply get:
TST:Tbl <undefined>
A B
Is that expected behavior, did I miss some configuration or this a bug? If it is a bug, where should this be raised first?
Less critical, when constructing more complex requests, like selecting multiple columns from a single table, the syntax between the two differs. Is that intended?
For example:
pvget -r "field(value{LMT_l,LTM_h}) BPMZ1D1R:signals:sa:pva
works, same thing with pvxget gives me "Error: invalid character near: {LMT_l,LTM_h})"
Conversely, a working request for pvxget is
pvxget -r "field(value.LMT_l,value.LTM_h)" BPMZ1D1R:signals:sa:pva
When doing the same with pvget, it complains: "failed to parse request string: Can't construct Structure, duplicate fieldName value"
I was under the impression that pvxs is the more forward-looking implementation and one could/should use it in an IOC. While for the command line tools pvAccessCPP is the recommend way (at least it says so in the pvxs documentation). How are others handling this and what could I do to resolve these issues?
Cheers,
Malte
Dr. Malte Gotz
Phone: +49 030 8062 15808
Accelerator Operation  - Control System Group
(BE-IA-AOT/ACS)
Aufsichtsrat: Vorsitzender Michael Zimmermann, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech, Saskia Vormfelde
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Re: pvget, pvxget and pvxs interoperability and differences Michael Davidsaver via Tech-talk
pvget, pvxget and pvxs interoperability and differences Gotz, Malte via Tech-talk
Prev: pvget, pvxget and pvxs interoperability and differences Gotz, Malte via Tech-talk
Next: EPICS SNMP compile error Peter Sx via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Next: Re: pvget, pvxget and pvxs interoperability and differences Michael Davidsaver via Tech-talk
