1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: E3 conda build problem
From: Anders Lindh Olsson via Tech-talk <tech-talk at aps.anl.gov>
To: Jörn Dreyer <j.dreyer at hzdr.de>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 12 Mar 2026 11:20:17 +0000
Hi Jörn,
You need to either comment out stdlib(’c’) or else provide the conda-forge pinning file. This is explained in the next paragraph from where you were.
Cheers
A
> On 12 Mar 2026, at 11:56, Jörn Dreyer via Tech-talk <tech-talk at aps.anl.gov> wrote:
> Hello,
> I tried to build the example from the E3 website (iocstats) in a environment created with micromamba.
> The conda build recipe command fails with:
>> Could not solve for environment specs
>> The following package could not be installed
>> └─ c_linux-64 =* * does not exist (perhaps a typo or a missing channel).
> From googling the error I know that it comes from the requirement { stdlib('c') }in recipe/meta.yaml for the build of the module.
> Does anybody know what could be wrong in my environment?
> Regards
> Jörn
> <Jörn Dreyer.vcf>
Re: E3 conda build problem Jörn Dreyer via Tech-talk
Prev: E3 conda build problem Jörn Dreyer via Tech-talk
Next: Re: AW: pvget, pvxget and pvxs interoperability and differences Peter Milne via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: Re: E3 conda build problem Jörn Dreyer via Tech-talk
