1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: E3 conda build problem
From: Jörn Dreyer via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Thu, 12 Mar 2026 14:17:43 +0100
Hi Anders,
that helped a bit, but now I seem to run into some recursion problem during the test pahse of the package.
It tries to find a iocsh command file in :
/home/wuestenf/micromamba/envs/conda-build/conda-bld/iocstats_1773318749191/_test_env_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placehold_placeho/ep/iocStats.iocsh
which does not exists, becaus it should end with placehold/epics_modules/iocstat/iocStat.iocsh.
Do you have an idea how this path name is constructed?
I am using the following packages in my environment:
 Name                       Version       Build                 Channel
  PythonQwt                  0.12.5        pypi_0                pypi
  _openmp_mutex              4.5           20_gnu                conda-forge
  aiohttp                    3.8.4         pypi_0                pypi
  aiosignal                  1.3.1         pypi_0                pypi
  ansible                    9.1.0         pypi_0                pypi
  ansible-core               2.16.2        pypi_0                pypi
  apischema                  0.18.0        pypi_0                pypi
  archspec                   0.2.5         pyhd8ed1ab_0          conda-forge
  async-timeout              4.0.2         pypi_0                pypi
  attrs                      25.4.0        pyhcf101f3_1          conda-forge
  backports.zstd             1.3.0         py310h69bd2ac_0       conda-forge
  beautifulsoup4             4.14.3        pyha770c72_0          conda-forge
  boltons                    25.0.0        pyhd8ed1ab_0          conda-forge
  brotli-python              1.2.0         py310hba01987_1       conda-forge
  bzip2                      1.0.8         hda65f42_9            conda-forge
  c-ares                     1.34.6        hb03c661_0            conda-forge
  ca-certificates            2026.2.25     hbd8a1cb_0            conda-forge
  certifi                    2026.2.25     pyhd8ed1ab_0          conda-forge
  cffi                       2.0.0         py310he7384ee_1       conda-forge
  chardet                    5.2.0         pyhd8ed1ab_3          conda-forge
  charset-normalizer         3.4.5         pyhd8ed1ab_0          conda-forge
  click                      8.3.1         pyh8f84b5b_1          conda-forge
  conda                      26.1.1        py310hff52083_0       conda-forge
  conda-build                26.1.0        pyh31ec981_102        conda-forge
  conda-index                0.7.0         pyhd8ed1ab_0          conda-forge
  conda-libmamba-solver      25.11.0       pyhd8ed1ab_1          conda-forge
  conda-package-handling     2.4.0         pyh7900ff3_2          conda-forge
  conda-package-streaming    0.12.0        pyhd8ed1ab_0          conda-forge
  conda-verify               3.4.2         pyhd8ed1ab_1          conda-forge
  cpp-expected               1.3.1         h171cf75_0            conda-forge
  distro                     1.9.0         pyhd8ed1ab_1          conda-forge
  epics-base                 7.0.9.0       pl5321h2669dad_10     conda-forge
  epicsmacrolib              0.6.0         pypi_0                pypi
  evalidate                  2.0.5         pyhe01879c_0          conda-forge
  figure                     1.1           pypi_0                pypi
  filelock                   3.25.1        pyhd8ed1ab_0          conda-forge
  fmt                        12.1.0        hff5e90c_0            conda-forge
  frozendict                 2.4.7         py310h7c4b9e2_0       conda-forge
  frozenlist                 1.3.3         pypi_0                pypi
  future                     1.0.0         pyhd8ed1ab_2          conda-forge
  graphql-core               3.2.3         pypi_0                pypi
  graphviz                   0.17          pypi_0                pypi
  guidata                    3.1.0         pypi_0                pypi
  guiqwt                     4.4.4         pypi_0                pypi
  h2                         4.3.0         pyhcf101f3_0          conda-forge
  h5py                       3.11.0        pypi_0                pypi
  hpack                      4.1.0         pyhd8ed1ab_0          conda-forge
  hyperframe                 6.1.0         pyhd8ed1ab_0          conda-forge
  icu                        78.2          h33c6efd_0            conda-forge
  idna                       3.11          pyhd8ed1ab_0          conda-forge
  jinja2                     3.1.6         pyhcf101f3_1          conda-forge
  jsonpatch                  1.33          pyhd8ed1ab_1          conda-forge
  jsonpointer                3.0.0         pyhcf101f3_3          conda-forge
  jsonschema                 4.26.0        pyhcf101f3_0          conda-forge
  jsonschema-specifications  2025.9.1      pyhcf101f3_0          conda-forge
  keyutils                   1.6.3         hb9d3cd8_0            conda-forge
  krb5                       1.22.2        ha1258a1_0            conda-forge
  lark                       1.1.5         pypi_0                pypi
  ld_impl_linux-64           2.45.1        default_hbd61a6d_101  conda-forge
  libarchive                 3.8.6         gpl_hc2c16d8_100      conda-forge
  libcurl                    8.19.0        hcf29cc6_0            conda-forge
  libedit                    3.1.20250104  pl5321h7949ede_0      conda-forge
  libev                      4.33          hd590300_2            conda-forge
  libevent                   2.1.12        hf998b51_1            conda-forge
  libexpat                   2.7.4         hecca717_0            conda-forge
  libffi                     3.5.2         h3435931_0            conda-forge
  libgcc                     15.2.0        he0feb66_18           conda-forge
  libgcc-ng                  15.2.0        h69a702a_18           conda-forge
  libgomp                    15.2.0        he0feb66_18           conda-forge
  libiconv                   1.18          h3b78370_2            conda-forge
  liblief                    0.17.1        hecca717_0            conda-forge
  liblzma                    5.8.2         hb03c661_0            conda-forge
  libmamba                   2.5.0         hd28c85e_0            conda-forge
  libmamba-spdlog            2.5.0         h12fcf84_0            conda-forge
  libmambapy                 2.5.0         py310h74f1d5f_0       conda-forge
  libnghttp2                 1.67.0        had1ee68_0            conda-forge
  libnsl                     2.0.1         hb9d3cd8_1            conda-forge
  libsolv                    0.7.35        h9463b59_0            conda-forge
  libsqlite                  3.52.0        hf4e2dac_0            conda-forge
  libssh2                    1.11.1        hcf80075_0            conda-forge
  libstdcxx                  15.2.0        h934c35e_18           conda-forge
  libstdcxx-ng               15.2.0        hdf11a46_18           conda-forge
  libuuid                    2.41.3        h5347b49_0            conda-forge
  libxcrypt                  4.4.36        hd590300_1            conda-forge
  libxml2                    2.15.2        he237659_0            conda-forge
  libxml2-16                 2.15.2        hca6bf5a_0            conda-forge
  libzlib                    1.3.1         hb9d3cd8_2            conda-forge
  lz4-c                      1.10.0        h5888daf_1            conda-forge
  lzo                        2.10          h280c20c_1002         conda-forge
  markupsafe                 3.0.3         py310h3406613_1       conda-forge
  mbedtls                    3.6.3.1       h5888daf_0            conda-forge
  menuinst                   2.4.2         py310hff52083_0       conda-forge
  msgpack-python             1.1.2         py310h03d9f68_1       conda-forge
  multidict                  6.0.4         pypi_0                pypi
  ncurses                    6.5           h2d0b736_3            conda-forge
  nlohmann_json-abi          3.12.0        h0f90c79_1            conda-forge
  openssl                    3.6.1         h35e630c_1            conda-forge
  packaging                  26.0          pyhcf101f3_0          conda-forge
  patch                      2.8           hb03c661_1002         conda-forge
  patchelf                   0.17.2        h58526e2_0            conda-forge
  perl                       5.32.1        7_hd590300_perl5      conda-forge
  pip                        26.0.1        pyh8b19718_0          conda-forge
  pkginfo                    1.12.1.2      pyhd8ed1ab_0          conda-forge
  platformdirs               4.9.4         pyhcf101f3_0          conda-forge
  plot                       0.6.5         pypi_0                pypi
  pluggy                     1.6.0         pyhf9edf01_1          conda-forge
  psutil                     7.2.2         py310h139afa4_0       conda-forge
  pvxs                       1.5.0         pl5321h579f993_1      conda-forge
  py-lief                    0.17.1        py310hea6c23e_0       conda-forge
  pybind11-abi               11            hc364b38_1            conda-forge
  pycosat                    0.6.6         py310h7c4b9e2_3       conda-forge
  pycparser                  2.22          pyh29332c3_1          conda-forge
  pyepics                    3.5.6         pypi_0                pypi
  pysocks                    1.7.1         pyha55dd90_7          conda-forge
  python                     3.10.20       h3c07f61_0_cpython    conda-forge
  python-libarchive-c        5.3           pyhe01879c_1          conda-forge
  python_abi                 3.10          8_cp310               conda-forge
  pytz                       2025.2        pyhd8ed1ab_0          conda-forge
  pyyaml                     6.0.3         py310h3406613_1       conda-forge
  readline                   8.3           h853b02a_0            conda-forge
  referencing                0.37.0        pyhcf101f3_0          conda-forge
  reproc                     14.2.5.post0  hb9d3cd8_0            conda-forge
  reproc-cpp                 14.2.5.post0  h5888daf_0            conda-forge
  requests                   2.32.5        pyhcf101f3_1          conda-forge
  require                    6.0.0         h2ce4039_1            ess-conda-local
  resolvelib                 1.0.1         pypi_0                pypi
  ripgrep                    15.1.0        hdab8a38_0            conda-forge
  rpds-py                    0.30.0        py310hd8f68c5_0       conda-forge
  ruamel.yaml                0.18.17       py310h139afa4_2       conda-forge
  ruamel.yaml.clib           0.2.15        py310h139afa4_1       conda-forge
  setuptools                 82.0.1        pyh332efcf_0          conda-forge
  simdjson                   4.2.4         hb700be7_0            conda-forge
  six                        1.17.0        pyhe01879c_1          conda-forge
  soupsieve                  2.8.3         pyhd8ed1ab_0          conda-forge
  spdlog                     1.17.0        hab81395_1            conda-forge
  tk                         8.6.13        noxft_h366c992_103    conda-forge
  tomli                      2.4.0         pyhcf101f3_0          conda-forge
  tqdm                       4.67.3        pyh8f84b5b_0          conda-forge
  truststore                 0.10.4        pyhcf101f3_0          conda-forge
  typing                     3.7.4.3       pypi_0                pypi
  typing-extensions          4.15.0        h396c80c_0            conda-forge
  typing_extensions          4.15.0        pyhcf101f3_0          conda-forge
  tzdata                     2025c         hc9c84f9_1            conda-forge
  urllib3                    2.6.3         pyhd8ed1ab_0          conda-forge
  whatrecord                 0.4.4         pypi_0                pypi
  wheel                      0.46.3        pyhd8ed1ab_0          conda-forge
  yaml                       0.2.5         h280c20c_3            conda-forge
  yaml-cpp                   0.8.0         h3f2d84a_0            conda-forge
  yarl                       1.9.2         pypi_0                pypi
  zstandard                  0.25.0        py310h139afa4_1       conda-forge
  zstd                       1.5.7         hb78ec9c_6            conda-forge
Jörn
Am Donnerstag, 12. März 2026, 12:20:17 Mitteleuropäische Normalzeit schrieb Anders Lindh Olsson via Tech-talk:
> Hi Jörn,
> You need to either comment out stdlib(’c’) or else provide the conda-forge pinning file. This is explained in the next paragraph from where you were.
> Cheers
> A
> > On 12 Mar 2026, at 11:56, Jörn Dreyer via Tech-talk <tech-talk at aps.anl.gov> wrote:
> > Hello,
> > I tried to build the example from the E3 website (iocstats) in a environment created with micromamba.
> > The conda build recipe command fails with:
> >> Could not solve for environment specs
> >> The following package could not be installed
> >> └─ c_linux-64 =* * does not exist (perhaps a typo or a missing channel).
> > From googling the error I know that it comes from the requirement { stdlib('c') }in recipe/meta.yaml for the build of the module.
> > Does anybody know what could be wrong in my environment?
> > Regards
> > Jörn
> > <Jörn Dreyer.vcf>
BEGIN:VCARD
VERSION:3.0
EMAIL;TYPE:j.dreyer at hzdr.de
FN:Jörn Dreyer
N:Dreyer;Jörn;;;
ORG:Helmholtz - Zentrum Dresden- Rossendorf;FWKX
TEL;TYPE=WORK:+0493502603263
TITLE:Dr.
UID:c191707b-eb41-4699-bb8d-a5ef050ab4aa
X-KADDRESSBOOK-MailPreferedFormatting:TEXT
END:VCARD
Re: E3 conda build problem Simon Rose via Tech-talk
E3 conda build problem Jörn Dreyer via Tech-talk
Re: E3 conda build problem Anders Lindh Olsson via Tech-talk
Prev: Re: AW: pvget, pvxget and pvxs interoperability and differences Peter Milne via Tech-talk
Next: Re: E3 conda build problem Simon Rose via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: E3 conda build problem Anders Lindh Olsson via Tech-talk
