1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: [SPAM] Re: the least EPICS_CA_MAX_ARRAY used for EIGER2 4M detector
From: Zhibang Shen via Tech-talk <tech-talk at aps.anl.gov>
To: "Johnson, Andrew N." <anj at anl.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 17 Mar 2026 18:44:10 +0800 (GMT+08:00)
Thank you for your help, now we are updating EPICS base to version 7.0.9. It works perfectly now.
Zhibang
-----原始邮件-----
发件人: "Johnson, Andrew N." <anj at anl.gov>
发送时间: 2026-02-27 18:10:38 (星期五)
收件人: "shenzb at ihep.ac.cn" <shenzb at ihep.ac.cn>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
主题: [SPAM] Re: the least EPICS_CA_MAX_ARRAY used for EIGER2 4M detector
If your IOC and CA client(s) were built using any EPICS 7.0.x release, EPICS_CA_MAX_ARRAY_BYTES is optional, and will be ignored unless your site has explicitly set EPICS_CA_AUTO_ARRAY_BYTES=NO (described in that link).
The elimination of these buffer-size issues is a good reason to update your EPICS Base version, especially where you’re dealing with large image data buffers.
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 2/27/26, 9:16 AM, "Tech-talk" <tech-talk-bounces at aps.anl.gov> wrote:
I am facing a problem with EPICS_CA_MAX_ARRAY_BYTES while using ADViewer monitoring Eiger2 4M detector.
I have followed the installation instruction of ADEiger and it works well. But if I set EPICS_CA_MAX_ARRAY_BYTES=10,000,000, ADViewer reports the exception of pendIO timed out. I also followed the troubleshooting to see whether all the configuration are properly set. The ArrayCallback PVs of cam1: and image1: are both set to Enable, and EPICS_CA_MAX_ARRAY is set to 40,000,000. I also tried EPICS_CA_MAX_ARRAY_BYTES=100,000,000 but it does not work either.
The pixel number of Eiger2 4M detector is 2068x2162=4,471,016. And the image bit depth is set to 32. I think the least EPICS_CA_MAX_ARRAY should be 2068x2162x4=17,884,064, then EPICS_CA_MAX_ARRAY_BYTES=40,000,000 should work. But it doesn't. I don't know why.
Could someone help me with this issue? Thanks in advance for any help.
Best regards,
Zhibang Shen
Institute of High Energy Physics, Chinese Academy of Sciences
19B Yuquan Road, Shijingshan District, Beijing, China
100049
the least EPICS_CA_MAX_ARRAY used for EIGER2 4M detector Zhibang Shen via Tech-talk
Re: the least EPICS_CA_MAX_ARRAY used for EIGER2 4M detector Johnson, Andrew N. via Tech-talk
Prev: question about pvmonitor behavior Alfio Rizzo via Tech-talk
Next: Re: Re: the least EPICS_CA_MAX_ARRAY used for EIGER2 4M detector Zhibang Shen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: the least EPICS_CA_MAX_ARRAY used for EIGER2 4M detector Johnson, Andrew N. via Tech-talk
Next: Re: the least EPICS_CA_MAX_ARRAY used for EIGER2 4M detector Mark Rivers via Tech-talk
