Hej
I noticed that the pvmonitor of a record value does not update when the .VAL is changed from the OUT field of another record,
E.g. Using this simple db
record(ai, "myaipv"){
field(PINI, "YES")
field(VAL, 100)
record(ao, "myaopv") {
field(PINI, "YES")
field(VAL, 30)
field(OUT, "myaipv")
If I do pvput myaovpv 1000, the myaipv.VAL is updated correctly (pvget myaipv gives back the updated value)
But this change is not shown in the pvmonitor STDOUT
According to what I heard this is the intended behavior, but why apparently it applies only to the .VAL field ?
I have tested the OUT with other fields like the alarm fields, or .RVAL , etc (i.e. OUT, "myaipv.HIHI") (OUT, "myaipv.RVAL")
Then if I do pvmonitor myaipv.HIHI for instance, everytime the myaopv value changes,
The pvmonitor reacts as well showing the updated .HIHI field value
Can someone give some more explanation about ?
I am using EPICS 7.0.9/6.0.0
Thanks
Best
Alfio
______________________
Alfio Rizzo
PhD / Automation Section Leader / ICS HW&I Group
European Spallation Source ERIC
P.O. Box 176, SE-221 00 Lund, Sweden
Visiting address: Partikelgatan 2, 224 84 Lund
Mobile: +46 72 179 23 42
E-mail:
alfio.rizzo at ess.eu
ess.eu
