1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: RE: Migrating an Archiver Appliance to a new machine
From: Sky Brewer via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, "windsor.tanner at aei.mpg.de" <windsor.tanner at aei.mpg.de>, Stephane Armanet <Stephane.Armanet at ess.eu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 18 Mar 2026 13:15:31 +0000
Hi Windsor,
From the last time we did this @Stephane Armanet notes were:
  • Deploy new VM
  • deploy new archiver and start with no config (also use another NFS share)
  • stop old archiver
  • import DB
  • shutdown and rename old VM
  • rename new VM to use the old name
  • update config to use the correct storage
  • start archiver with old DB and prod NFS share
  • re-use the old IP on new VM
    • Our appliances.xml uses ip addresses instead of hostnames ☹️
Sent from Outlook for Mac
Prev: Re: EPICS SNMP compile error Priller, John via Tech-talk
Next: Re: OPC UA Device Support - Limit in the number of PVs Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Prev: Migrating an Archiver Appliance to a new machine Windsor Tanner via Tech-talk
Next: question about pvmonitor behavior Alfio Rizzo via Tech-talk
