You need to add the PP attribute to the OUT field if you want myaipv to process. Otherwise it writes the value, but does not process the record, so no monitor is posted.
field(OUT, "myaipv PP")
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Alfio Rizzo via Tech-talk <tech-talk at aps.anl.gov>
Sent: Tuesday, March 17, 2026 5:27 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: question about pvmonitor behavior
Hej
I noticed that the pvmonitor of a record value does not update when the .VAL is changed from the OUT field of another record,
E.g. Using this simple db
record(ai, "myaipv"){
field(PINI, "YES")
field(VAL, 100)
record(ao, "myaopv") {
field(PINI, "YES")
field(VAL, 30)
field(OUT, "myaipv")
If I do pvput myaovpv 1000, the myaipv.VAL is updated correctly (pvget myaipv gives back the updated value)
But this change is not shown in the pvmonitor STDOUT
According to what I heard this is the intended behavior, but why apparently it applies only to the .VAL field ?
I have tested the OUT with other fields like the alarm fields, or .RVAL , etc (i.e. OUT, "myaipv.HIHI") (OUT, "myaipv.RVAL")
Then if I do pvmonitor myaipv.HIHI for instance, everytime the myaopv value changes,
The pvmonitor reacts as well showing the updated .HIHI field value
Can someone give some more explanation about ?
I am using EPICS 7.0.9/6.0.0
Thanks
Best
Alfio
______________________
Alfio Rizzo
PhD / Automation Section Leader / ICS HW&I Group
European Spallation Source ERIC
P.O. Box 176, SE-221 00 Lund, Sweden
Visiting address: Partikelgatan 2, 224 84 Lund
Mobile: +46 72 179 23 42
E-mail:
alfio.rizzo at ess.eu
[ess.eu]ess.eu
