1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: scalcout EPICS Record Error
From: Varuna Crishan Meddage via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 20 Mar 2026 22:29:47 +0000
Hi Mark,
Below is the output.
iocdev1$ ./startGPS.bash
/export/home1/vmeddage/EPICS_development/Create_GPS_IOC/iocTops/GPS
#!../../bin/linux-x86_64/GPS
< envPaths
epicsEnvSet("IOC","iocGPS")
epicsEnvSet("TOP","/export/home1/vmeddage/EPICS_development/Create_GPS_IOC/iocTops/GPS")
epicsEnvSet("EPICS_BASE","/usr/local/epics/base")
epicsEnvSet("SUPPORT","/usr/local/epics/Support")
epicsEnvSet("SNCSEQ","/usr/local/epics/Support/seq")
epicsEnvSet("ASYN","/usr/local/epics/Support/asyn")
epicsEnvSet("IPAC","/usr/local/epics/Support/ipac")
epicsEnvSet("CALC","/usr/local/epics/Support/calc")
epicsEnvSet("STD","/usr/local/epics/Support/std")
epicsEnvSet("SSCAN","/usr/local/epics/Support/sscan")
epicsEnvSet("STREAM","/usr/local/epics/Support/StreamDevice")
epicsEnvSet("BUSY","/usr/local/epics/Support/busy")
epicsEnvSet("IOCSTATS","/usr/local/epics/Support/iocStats")
epicsEnvSet("LINSTAT","/usr/local/epics/Support/linStat")
epicsEnvSet("LUA","/usr/local/epics/Support/lua")
epicsEnvSet("PCRE","/usr/local/epics/Support/pcre")
epicsEnvSet("SNMP","/usr/local/epics/Support/snmp")
epicsEnvSet("ACNETPV","/usr/local/epics/Support/acnetPV")
epicsEnvSet("ALIVE","/usr/local/epics/Support/alive")
epicsEnvSet("TCAST","/usr/local/epics/Support/tcast")
epicsEnvSet("RECASTER","/usr/local/epics/Support/RecCaster")
epicsEnvSet("AUTOSAVE","/usr/local/epics/Support/autosave")
epicsEnvSet("PUTLOG","/usr/local/epics/Support/caPutLog")
cd "/export/home1/vmeddage/EPICS_development/Create_GPS_IOC/iocTops/GPS"
## NTP Time Synchronisation
epicsEnvSet("EPICS_TS_NTP_INET","131.225.121.105")
## Do OS-specific startup here
epicsEnvSet("EPICS_HOST_ARCH","linux-x86_64")
epicsEnvSet("ENGINEER","vmeddage")
epicsEnvSet("LOCATION","BTE-106")
epicsEnvSet("EPICS_IOC_OWNER","vmeddage")
epicsEnvSet("EPICS_IOC_GROUP","FE_group")
epicsEnvSet("EPICS_IOC_LOCATION","BTE-106")
epicsEnvSet("IOCDIR","GPS")
epicsEnvSet("MIBDIRS","+/export/home1/vmeddage/EPICS_development/Create_GPS_IOC/iocTops/GPS/mibs")
dbLoadDatabase("/export/home1/vmeddage/EPICS_development/Create_GPS_IOC/iocTops/GPS/dbd/GPS.dbd",0,0)
GPS_registerRecordDeviceDriver(pdbbase)
INFO: PVXS QSRV2 is loaded, permitted, and ENABLED.
dbRegisterServer: Ignoring 'rsrv', per environment
## SNMP specifics
devSnmpSetSnmpVersion(10.200.34.12,SNMP_VERSION_2C)
devSnmpSetParam("DebugLevel",2)
devSnmp: debug level level is now 2
devSnmp set DebugLevel to 2 (was 0)
devSnmpSetParam("SessionTimeout", "1000000")
devSnmp set SessionTimeout to 1000000 (was 10000000)
## Load record instances
#dbLoadRecords("${EPICS_IOCTOPS}/${IOCDIR}/db/GPSalive.db")
#dbLoadRecords("${EPICS_IOCTOPS}/${IOCDIR}/db/GPSwatcher.db")
#dbLoadRecords("${EPICS_IOCTOPS}/${IOCDIR}/db/GPSiocAdminSoft.db")
#dbLoadRecords("${EPICS_IOCTOPS}/${IOCDIR}/db/GPSAcnetDevice.db")
#dbLoadRecords("${EPICS_IOCTOPS}/${IOCDIR}/db/GPSExtra.db")
#dbLoadRecords("${EPICS_IOCTOPS}/${IOCDIR}/db/GPStcast.db")
#dbLoadRecords("${EPICS_IOCTOPS}/${IOCDIR}/db/GPSRecCaster.db")
dbLoadRecords("/export/home1/vmeddage/EPICS_development/Create_GPS_IOC/iocTops/GPS/db/gps_novus.db")
#dbLoadRecords("${EPICS_IOCTOPS}/${IOCDIR}/db/test.db")
## Put logging and access security
epicsEnvSet("EPICS_CA_JSON_PUT_LOG_ADDR","/home/epics/epicsDEV/PutLog/test.json")
asSetFilename("/export/home1/vmeddage/EPICS_development/Create_GPS_IOC/iocTops/GPS/iocBoot/iocGPS/ioc.acf")
iocInit()
Starting iocInit
## EPICS R7.0.9
## Rev. R7.0.9-dirty
## Rev. Date Git: 2025-02-21 17:31:33 -0600
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel1Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel2Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel3Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel4Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel5Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel6Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel7Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel8Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel9Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel10Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel11Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel12Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel13Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel14Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel15Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel16Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel17Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel18Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel19Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel20Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel21Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel22Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel23Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel24Vrms
caPutJsonLogInit localhost:7011
## Create as many matching Acnet devices as needed and uncomment
#createAcnetDeviceRecord Z:GPSGPS
dbpf PIP2:TIME_CTRL_GPS:alive.EV1 linux-x86_64
PV 'PIP2:TIME_CTRL_GPS:alive.EV1' not found
dbpf PIP2:TIME_CTRL_GPS:alive.EV2 7.0.9
PV 'PIP2:TIME_CTRL_GPS:alive.EV2' not found
dbpf PIP2:TIME_CTRL_GPS:alive.EV3 /usr/local/epics/base
PV 'PIP2:TIME_CTRL_GPS:alive.EV3' not found
log client: failed to connect to server '127.0.0.1:7011' because 'Connection refused'
dbpf PIP2:TIME_CTRL_GPS:alive.EV4 /usr/local/epics/Support
PV 'PIP2:TIME_CTRL_GPS:alive.EV4' not found
dbpf PIP2:TIME_CTRL_GPS:alive.EV5 vmeddage
PV 'PIP2:TIME_CTRL_GPS:alive.EV5' not found
dbpf PIP2:TIME_CTRL_GPS:alive.EV6 BTE-106
PV 'PIP2:TIME_CTRL_GPS:alive.EV6' not found
dbpf PIP2:TIME_CTRL_GPS:alive.EV7 "Front Ends"
PV 'PIP2:TIME_CTRL_GPS:alive.EV7' not found
PIP2:TIME_CTRL_GPS:calc_nsChannel1Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel2Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel3Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel4Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel5Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel6Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel7Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel8Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel9Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel10Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel11Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel12Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel13Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel14Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel15Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel16Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel17Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel18Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel19Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel20Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel21Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel22Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel23Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel24Vrms DSET write does not exist
Sent: Friday, March 20, 2026 5:18 PM
To: Varuna Crishan Meddage <vmeddage at fnal.gov>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
[EXTERNAL] – This message is from an external sender
I have never seen an error like:
I don't know what the (514,3) means.
It seems like it could be a problem with missing device support or something.
Can you send the complete output when the IOC boots.
From: Varuna Crishan Meddage <vmeddage at fnal.gov>
Sent: Friday, March 20, 2026 5:00 PM
To: Mark Rivers <rivers at cars.uchicago.edu>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Hi Mark,
Thanks for the suggestion,
I implemented what you have suggested as follows.
record(stringin, "$(acc):$(sys)_$(group):nsChannel$(channel_id)Vrms")
  field(SCAN, "10 second")
  field(DTYP, "Snmp")
  field(INP, "@$(HOST) $(COMMUNITY) $(W)::nsChannel$(channel_id)Vrms.0 STRING: 100")
  field(DESC, "Channel $(channel_id) Vrms")
  field(FLNK, "$(acc):$(sys)_$(group):calc_nsChannel$(channel_id)Vrms")
record(scalcout, "$(acc):$(sys)_$(group):calc_nsChannel$(channel_id)Vrms")
  field(INAA, "$(acc):$(sys)_$(group):nsChannel$(channel_id)Vrms")
  field(CALC, "LEN(AA)==0?0:DBL(AA)")
  field(PREC, "2")
  field(EGU, "V")
But still get the following error messages in runtime.
================================= ERROR =====================
Sent: Thursday, March 19, 2026 8:23 PM
To: Mark Rivers <rivers at cars.uchicago.edu>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>; Varuna Crishan Meddage <vmeddage at fnal.gov>
Whoops the DBL argument should be AA too:
  field(CALC, "LEN(AA)==0 ? 0 : DBL(AA)")
Sent from my iPhone
On Mar 19, 2026, at 7:45 PM, Mark Rivers <rivers at cars.uchicago.edu> wrote:
  field(CALC, "LEN(AA)==0 ? 0 : DBL(A)")
scalcout EPICS Record Error Varuna Crishan Meddage via Tech-talk
Re: scalcout EPICS Record Error Mark Rivers via Tech-talk
Re: scalcout EPICS Record Error Varuna Crishan Meddage via Tech-talk
Prev: Re: scalcout EPICS Record Error Mark Rivers via Tech-talk
Next: Re: scalcout EPICS Record Error Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
ANJ, 20 Mar 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
