1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: scalcout EPICS Record Error
From: "Johnson, Andrew N. via Tech-talk" <tech-talk at aps.anl.gov>
To: Varuna Crishan Meddage <vmeddage at fnal.gov>, "Rivers, Mark L." <rivers at cars.uchicago.edu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 20 Mar 2026 22:32:27 +0000
These errors aren’t from the values given in your database at all, they are being reported by the scalcout record implementation indicating there was an error in your IOC's build or link stage.
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel1Vrms
The (514,3) above should normally be translated into a string, so your error symbol table isn’t being initialized properly. Then those particular numbers mean S_dev_noDSET: Missing device support entry table.
The scalcout record has a Soft Channel device support (devsCalcoutSoft), but it hasn’t been registered properly in the IOC’s DBD file so the code the record needs to run hasn’t been loaded.
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 3/20/26, 5:00 PM, "Tech-talk" <tech-talk-bounces at aps.anl.gov> wrote:
Hi Mark,
Thanks for the suggestion,
I implemented what you have suggested as follows.
record(stringin, "$(acc):$(sys)_$(group):nsChannel$(channel_id)Vrms")
  field(SCAN, "10 second")
  field(DTYP, "Snmp")
  field(INP, "@$(HOST) $(COMMUNITY) $(W)::nsChannel$(channel_id)Vrms.0 STRING: 100")
  field(DESC, "Channel $(channel_id) Vrms")
  field(FLNK, "$(acc):$(sys)_$(group):calc_nsChannel$(channel_id)Vrms")
record(scalcout, "$(acc):$(sys)_$(group):calc_nsChannel$(channel_id)Vrms")
  field(INAA, "$(acc):$(sys)_$(group):nsChannel$(channel_id)Vrms")
  field(CALC, "LEN(AA)==0?0:DBL(AA)")
  field(PREC, "2")
  field(EGU, "V")
But still get the following error messages in runtime.
================================= ERROR =====================
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel2Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel3Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel4Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel5Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel6Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel7Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel8Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel9Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel10Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel11Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel12Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel13Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel14Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel15Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel16Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel17Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel18Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel19Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel20Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel21Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel22Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel23Vrms
recGblRecordError: scalcout:init_record Error (514,3) PV: PIP2:TIME_CTRL_GPS:calc_nsChannel24Vrms
caPutJsonLogInit localhost:7011
## Create as many matching Acnet devices as needed and uncomment
#createAcnetDeviceRecord Z:GPSGPS
PIP2:TIME_CTRL_GPS:calc_nsChannel1Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel2Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel3Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel4Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel5Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel6Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel7Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel8Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel9Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel10Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel11Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel12Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel13Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel14Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel15Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel16Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel17Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel18Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel19Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel20Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel21Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel22Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel23Vrms DSET write does not exist
PIP2:TIME_CTRL_GPS:calc_nsChannel24Vrms DSET write does not exist
Sent: Thursday, March 19, 2026 8:23 PM
To: Mark Rivers <rivers at cars.uchicago.edu>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>; Varuna Crishan Meddage <vmeddage at fnal.gov>
[EXTERNAL] – This message is from an external sender
Whoops the DBL argument should be AA too:
  field(CALC, "LEN(AA)==0 ? 0 : DBL(AA)")
Sent from my iPhone
On Mar 19, 2026, at 7:45 PM, Mark Rivers <rivers at cars.uchicago.edu> wrote:
  field(CALC, "LEN(AA)==0 ? 0 : DBL(A)")
Re: scalcout EPICS Record Error Varuna Crishan Meddage via Tech-talk
Re: scalcout EPICS Record Error Mark Rivers via Tech-talk
Prev: Re: scalcout EPICS Record Error Varuna Crishan Meddage via Tech-talk
Next: Re: scalcout EPICS Record Error Varuna Crishan Meddage via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
ANJ, 20 Mar 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
