1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: RE: OPC UA Device Support - Limit in the number of PVs [SEC=OFFICIAL]
From: "STARRITT, Andrew via Tech-talk" <tech-talk at aps.anl.gov>
To: eusebio_naif AL-SOLIMAN FUENTES <eunaif at go.ugr.es>, Ralph Lange <ralph.lange at gmx.de>
Cc: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Mon, 23 Mar 2026 06:08:55 +0000
Hi, Eusebio,
When I ran into this situation with a new server (can’t recall which model), I just created two sessions
and two associated subscriptions. It was fairly easy to arrange an approx 50-50 split in the associated
substitution file. Might not have been the “best” solution but did solve the problem.
Cheers
Andrew
OFFICIAL
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of eusebio_naif AL-SOLIMAN FUENTES via Tech-talk
Sent: Saturday, 21 March 2026 1:17 AM
To: Ralph Lange <ralph.lange at gmx.de>
Subject: Re: OPC UA Device Support - Limit in the number of PVs
CAUTION, EXTERNAL EMAIL: This message has come from outside of ANSTO. Do not take action, click links or open attachments unless you trust the source of this message and know the content is safe. Report spam and phishing using the Report Message button or if unsure, forward this message to servicedesk at ansto.gov.au as an attachment.
Hello Ralph.
Thanks for your response. In that case, I will check the configuration of my OPC UA server.
Best regards, Eusebio.
El mié, 18 mar 2026 a las 14:29, Ralph Lange via Tech-talk (<tech-talk at aps.anl.gov>) escribió:
What is your server?
That looks like a limitation on the server side, either on the total number of items per session or per subscription (I know a few servers doing that) or on the number of items per OPC UA service call (e.g., Siemens S7 has a limit of 1000) or on the number of registered items (I know a few servers doing that).
Getting BadConnectionClosed means that your server probably closed the connection after it found you were going over its limits. Brutal but not unheard of. (It's a simple way to avoid DoS-type attacks.)
If the item is not connected, any processing that leads to a conversion of a value to an unknown OPC UA type will fail - these are follow-up errors.
If you think the error message should be improved, please open an issue in the GitHub project.
Cheers,
~Ralph
Eusebio N. Al-Soliman
PhD Student
Departamento de Ingeniería de Computadores, Automática y Robótica
University of Granada
18008, Granada, Spain | eunaif at go.ugr.es
OPC UA Device Support - Limit in the number of PVs eusebio_naif AL-SOLIMAN FUENTES via Tech-talk
Re: OPC UA Device Support - Limit in the number of PVs Ralph Lange via Tech-talk
Re: OPC UA Device Support - Limit in the number of PVs eusebio_naif AL-SOLIMAN FUENTES via Tech-talk
Prev: Re: scalcout EPICS Record Error Varuna Crishan Meddage via Tech-talk
Next: EPICS Summer School 2026 at the European Spallation Source Timo Korhonen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: OPC UA Device Support - Limit in the number of PVs eusebio_naif AL-SOLIMAN FUENTES via Tech-talk
Next: Handling epicsParseDouble Errors from SNMP PVs Returning Empty or Unexpected Values Varuna Crishan Meddage via Tech-talk
ANJ, 23 Mar 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
