1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Re: Cross compiling for arm
From: Lucas Magalhães via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 24 Mar 2026 08:59:56 +0000
Hi David,
For the cross compilation to ppc64 we do at ESS we setup CONFIG_SITE.Common.linux-ppc64 and define the "GNU_" macros so EPICS build system figures out how to find them. Here is an example https://urldefense.us/v3/__https://gitlab.esss.lu.se/e3/wrappers/e3-base/-/blob/master/configure/os/CONFIG_SITE.Common.linux-ppc64e6500?ref_type=heads*L50-58__;Iw!!G_uCfscf7eWS!c255j21zl5ZoG_0PhAFc7MBrUfaTIb0ZhRMPoJWc4o9O4kIrQTfwbkX5PpPacev3tO_0wMX1Dgvv88FYnKIkLKX13JDuU3M$
Cheers,
Lucas A. M. Magalhaes.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Dudley, David via Tech-talk <tech-talk at aps.anl.gov>
Sent: Friday, March 20, 2026 20:20
To: tech-talk at aps.anl.gov
Subject: Cross compiling for arm
Working on cross compiling EPICS for arm (and aarch64…)  I’ve got CONFIG_SITE.linux-x86.linux-arm set for where the compiler is located, but how do I tell the build system where the include files and libraries are located?
Later-
Later-
David
Cross compiling for arm Dudley, David via Tech-talk
Prev: Looking for mutex contention in Linux IOCs Michael Davidsaver via Tech-talk
Next: Re: MAXnet Alarm State Under High Motor Command Load Mrinal Bera via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Prev: Cross compiling for arm Dudley, David via Tech-talk
Next: EPICS Summer School 2026 at the European Spallation Source Timo Korhonen via Tech-talk
ANJ, 24 Mar 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
