1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: How to configure waveform record to read remote PV via PVAccess in EPICS
From: Varuna Crishan Meddage via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 25 Mar 2026 19:13:15 +0000
I am trying to create a waveform record in my IOC that takes its values from a remote PV hosted on another serverusing EPICS PVAccess (PVA).
Here’s what I want to achieve:
  • Define a waveform record locally (e.g., LOCAL:WF)
  • Subscribe to a remote PV (e.g., REMOTE:ARRAY:PV) on a server with a known IP address and port
  • Automatically update the waveform at a set scan rate
I am unsure about the exact configuration. Specifically, I would like guidance on:
  1. Waveform record DB definition – how should the DTYP and INP fields be set to read from the remote PV?
  2. Specifying the server IP and port in the INP field.
  3. Any pitfalls, such as array size (NELM) matching or data type requirements.
For example, would a record like this work?
record(waveform, "LOCAL:WF") {
    field(DTYP, "pvaClientWaveform")
    field(INP, "PVA:REMOTE:ARRAY:[email protected]:5075")
    field(SCAN, "1 second")
    field(NELM, "4096")
I would greatly appreciate any example .db record, IOC DBD configuration, or startup instructions for properly using a remote PV with waveform records via PVA.
My base EPICS version is : epics-base-R7.0.9-328
Thanks
Varuna Meddage
Re: How to configure waveform record to read remote PV via PVAccess in EPICS Kasemir, Kay via Tech-talk
Re: How to configure waveform record to read remote PV via PVAccess in EPICS Michael Davidsaver via Tech-talk
Re: How to configure waveform record to read remote PV via PVAccess in EPICS Sukhanov, Andrei via Tech-talk
Prev: Re: [EXTERNAL] Re: CA gateway crashes periodically due to badly behaved servers Brian Bevins via Tech-talk
Next: Re: How to configure waveform record to read remote PV via PVAccess in EPICS Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Lack of error message from invalid CROSS_COMPILER_TARGET_ARCHS Wells, Alex (DLSLtd,RAL,TEC) via Tech-talk
ANJ, 25 Mar 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
