1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: How to configure waveform record to read remote PV via PVAccess in EPICS
From: "Sukhanov, Andrei via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, Varuna Crishan Meddage <vmeddage at fnal.gov>
Date: Thu, 26 Mar 2026 00:12:31 +0000
Hi Varuna,
Here is an example how to create and modify waveform PV sourced from remote PV using python p4p:
import time
import numpy as np
from p4p.server.thread import SharedPV
from p4p.server import Server
from p4p.nt import NTScalar
from p4p.client.thread import Context
ctxt = Context('pva')
# create output PVs, if needed
pv = SharedPV(nt=NTScalar('ah'), initial=[0])# int16 array
# callback function to double the input array
def callback(V):
      ar = np.array(V)
      pv.post(np.array(V)*2)
callback = ctxt.monitor('epicsDev0:c01Waveform', callback)
with Server(providers=[{'my:array': pv}]):
      while True:
            # do something else or sleep.
            time.sleep(1)
/Andrey
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Varuna Crishan Meddage via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, March 25, 2026 3:13 PM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: How to configure waveform record to read remote PV via PVAccess in EPICS
I am trying to create a waveform record in my IOC that takes its values from a remote PV hosted on another serverusing EPICS PVAccess (PVA). Here’s what I want to achieve: Define a waveform record locally (e. g. , LOCAL: WF) Subscribe to a remote
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
  • Define a waveform record locally (e.g., LOCAL:WF)
  • Subscribe to a remote PV (e.g., REMOTE:ARRAY:PV) on a server with a known IP address and port
  • Automatically update the waveform at a set scan rate
I am unsure about the exact configuration. Specifically, I would like guidance on:
  1. Waveform record DB definition – how should the DTYP and INP fields be set to read from the remote PV?
  2. Specifying the server IP and port in the INP field.
  3. Any pitfalls, such as array size (NELM) matching or data type requirements.
For example, would a record like this work?
record(waveform, "LOCAL:WF") {
    field(DTYP, "pvaClientWaveform")
    field(INP, "PVA:REMOTE:ARRAY:[email protected]:5075")
    field(SCAN, "1 second")
    field(NELM, "4096")
I would greatly appreciate any example .db record, IOC DBD configuration, or startup instructions for properly using a remote PV with waveform records via PVA.
My base EPICS version is : epics-base-R7.0.9-328
Thanks
Varuna Meddage
How to configure waveform record to read remote PV via PVAccess in EPICS Varuna Crishan Meddage via Tech-talk
Prev: Re: How to configure waveform record to read remote PV via PVAccess in EPICS Varuna Crishan Meddage via Tech-talk
Next: Re: How to configure waveform record to read remote PV via PVAccess in EPICS Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: PVA via sshuttel tunnel Jörn Dreyer via Tech-talk
ANJ, 31 Mar 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
