1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: How to configure waveform record to read remote PV via PVAccess in EPICS
From: Varuna Crishan Meddage via Tech-talk <tech-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 26 Mar 2026 16:09:29 +0000
Hi Michalel
Following is the output after printing out ENV variables.
iocdev1$ env | grep EPICS_PVA
EPICS_PVA_ADDR_LIST=239.128.1.6,8@eno1 10.200.21.28 10.200.21.29 10.200.12.73 10.200.16.47 10.200.16.40 10.200.16.58 10.200.16.59
EPICS_PVAS_INTF_ADDR_LIST=239.128.1.6
EPICS_PVAS_AUTO_BEACON_ADDR_LIST=NO
EPICS_PVA_AUTO_ADDR_LIST=NO
EPICS_PVAS_BEACON_ADDR_LIST=239.128.1.7,10
=============================== INSIDE EPICS SESSIION =============================
epics> pvxsr
EPICS_PVAS_BEACON_ADDR_LIST=239.128.1.7:5076,10
EPICS_PVAS_BROADCAST_PORT=5076
EPICS_PVAS_IGNORE_ADDR_LIST=
EPICS_PVAS_INTF_ADDR_LIST=239.128.1.6:5075,-1 0.0.0.0
EPICS_PVAS_SERVER_PORT=40515
Source: __builtin prio=-1
Source: __server prio=-1
Source: acnet prio=0
Source: qsrvSingle prio=0
Source: qsrvGroup prio=1
From: Michael Davidsaver <mdavidsaver at gmail.com>
Sent: Wednesday, March 25, 2026 7:47 PM
To: Varuna Crishan Meddage <vmeddage at fnal.gov>
Cc: kasemirk at ornl.gov <kasemirk at ornl.gov>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
[EXTERNAL] – This message is from an external sender
On 3/25/26 1:54 PM, Varuna Crishan Meddage wrote:
I created the following PV
record(waveform, "PIP2:CTRL_MPS:acq2106_current")
  field(INP, {pva:{pv:"acq2106_347:1:AI:WF:17", "proc":"CPP"}})
  field(FTVL, "DOUBLE")
  field(NELM, "4096")
  field(SCAN, "1 second")
But it complains that input PV is disconnected.
iocdev1$ pvxget acq2106_347:1:AI:WF:17
Is your IOC running with the same PVA configuration (environment variables) as your shell session?
fyi. At the IOC shell, run "pvxsr" to see the effective configuration (after auto address list expansion).
epics> pvxsr
EPICS_PVAS_BEACON_ADDR_LIST=192.168.1.255 10.127.127.255
EPICS_PVAS_INTF_ADDR_LIST=0.0.0.0
EPICS_PVAS_SERVER_PORT=5075
eg. If I run one instance of softIocPVX with
record(calc, "counter") {
    field(CALC, "VAL+1")
And a second with
record(longin, "follower") {
    field(INP, {pva:{pv:"counter", "proc":"CP"}})
I see that the "follower" record subscribes to the "counter"
epics> dbgf follower
DBF_LONG:           59 = 0x3b
DBF_LONG:           60 = 0x3c
Re: How to configure waveform record to read remote PV via PVAccess in EPICS Michael Davidsaver via Tech-talk
How to configure waveform record to read remote PV via PVAccess in EPICS Varuna Crishan Meddage via Tech-talk
Re: How to configure waveform record to read remote PV via PVAccess in EPICS Varuna Crishan Meddage via Tech-talk
Prev: Re: How to configure waveform record to read remote PV via PVAccess in EPICS Johnson, Andrew N. via Tech-talk
Next: PVA via sshuttel tunnel Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: How to configure waveform record to read remote PV via PVAccess in EPICS Michael Davidsaver via Tech-talk
Next: Re: How to configure waveform record to read remote PV via PVAccess in EPICS Michael Davidsaver via Tech-talk
ANJ, 30 Mar 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
