1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Turning off despeckle filter in ADKinetix
From: "Wlodek, Jakub via Tech-talk" <tech-talk at aps.anl.gov>
To: Prabudhya Bhattacharyya <pbhattacharyya at sigray.com>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 7 Apr 2026 12:17:20 +0000
Hi Pra,
I am the author of the ADKinetix driver - I believe I haven't yet exposed the functionality for configuring post-processing settings for the camera, but it should be relatively straightforward to do so. I am out of office until Thursday, but I can work on it once I'm back - I will let you know once I have a PR up with the functionality for you to try out.
Best,
Jakub
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Prabudhya Bhattacharyya via Tech-talk <tech-talk at aps.anl.gov>
Sent: Monday, April 6, 2026 7:58:53 PM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Turning off despeckle filter in ADKinetix
Hi all,  We are using the ADKinetix driver for a Kinetix detector. Is there a way to disable despeckle filtering on the camera? As I understand it, this is part of the post processing built into the PVCam SDK. Does ADKinetix allow users to change
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Hi all,
We are using the ADKinetix driver for a Kinetix detector. Is there a way to disable despeckle filtering on the camera? As I understand it, this is part of the post processing built into the PVCam SDK. Does ADKinetix allow users to change these parameters?
Thanks.
Pra
The content of this message is APPLIED MATERIALS CONFIDENTIAL. If you are not the intended recipient, please notify me, delete this email and do not use or distribute this email.
Turning off despeckle filter in ADKinetix Prabudhya Bhattacharyya via Tech-talk
Prev: WEISS 1.0.0 release André Favoto via Tech-talk
Next: Re: MAXnet Alarm State Under High Motor Command Load Peterson, Kevin M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Turning off despeckle filter in ADKinetix Prabudhya Bhattacharyya via Tech-talk
Next: WEISS 1.0.0 release André Favoto via Tech-talk
ANJ, 07 Apr 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
