1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Turning off despeckle filter in ADKinetix
From: Prabudhya Bhattacharyya via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Mon, 6 Apr 2026 16:58:53 -0700
Hi all,
We are using the ADKinetix driver for a Kinetix detector. Is there a way to disable despeckle filtering on the camera? As I understand it, this is part of the post processing built into the PVCam SDK. Does ADKinetix allow users to change these parameters?
Thanks.
Pra
The content of this message is APPLIED MATERIALS CONFIDENTIAL. If you are not the intended recipient, please notify me, delete this email and do not use or distribute this email.
Re: Turning off despeckle filter in ADKinetix Wlodek, Jakub via Tech-talk
Prev: RTEMS/MVME2100 OMS58 card does not exist! error Miroslaw Dach via Tech-talk
Next: Re: PVA via sshuttel tunnel Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: RTEMS/MVME2100 OMS58 card does not exist! error Miroslaw Dach via Tech-talk
Next: Re: Turning off despeckle filter in ADKinetix Wlodek, Jakub via Tech-talk
ANJ, 14 Apr 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
