1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Re: PVA via sshuttel tunnel
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: Jörn Dreyer <j.dreyer at hzdr.de>
Cc: tech-talk at aps.anl.gov
Date: Mon, 6 Apr 2026 19:33:38 -0700
On 3/27/26 12:59 AM, Jörn Dreyer via Tech-talk wrote:
Hi Folks,
I have a problem with remote access to my EPICS pvagw using sshuttle as tunnel into my lab network.
If I enable on the gateway the debug output, I see the request I send from home and that it gets processed correctly by the gateway.
It ask the IOC for the PV and sends the answer correctly back to my entry host. But on the client side at home I get a timeout.
If I uase the ca protocol over sshuttle to another ioc running in the lab network everything works correctly.
Does anybody know ho to get that combination running?
I had not heard of "sshuttle" before.  At a guess, port numbers are probably being remapped.  PVA does not handle this well.
Personally, I can usually make due with forwarding only TCP and making use of EPICS_PVA_NAME_SERVER.  For simple situations, I can point the client directly at a single IOC.  For more complex situations, I can configure a p4p.gw to listen on TCP port 15064.  Forward that port with SSH.  Then point my client at "EPICS_PVA_NAME_SERVER=127.0.0.1:15064".
Re: PVA via sshuttel tunnel Jörn Dreyer via Tech-talk
Prev: Turning off despeckle filter in ADKinetix Prabudhya Bhattacharyya via Tech-talk
Next: WEISS 1.0.0 release André Favoto via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Prev: PVA via sshuttel tunnel Jörn Dreyer via Tech-talk
Next: Re: PVA via sshuttel tunnel Jörn Dreyer via Tech-talk
ANJ, 10 Apr 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
