1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: PVA via sshuttel tunnel
From: Jörn Dreyer via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Cc: tech-talk at aps.anl.gov
Date: Fri, 10 Apr 2026 08:54:56 +0200
Hi Folks,
I did some more tests with sshuttle and phoebus. To get this combination working I had to set up the
"org.phoebus.pv.pva/epics_pva_name_servers" preference variable in my settings.ini file and uncomment the "org.phoebus.pv.pva/epics_pva_addr_list".
But if I am in the same network in the lab, I have to enable "org.phoebus.pv.pva/epics_pva_addr_list". Otherwise phoebus will need significant more time
to read the PV's from my IOC.
I still need to configure sshuttle differently. Currently I am limited to about 900kb on an 600MBit uplink from home which comes probably
from the latency control in sshuttle as suggested from report on the internet. Disabling that hopefully will give me higher transfer speeds.
I choose sshuttle to connect phoebus and my IOC because I have multiple IOC's I want to access and I am not allowed to run a gateway on our login node.
Jörn
Am Dienstag, 7. April 2026, 04:33:38 Mitteleuropäische Sommerzeit schrieb Michael Davidsaver via Tech-talk:
> On 3/27/26 12:59 AM, Jörn Dreyer via Tech-talk wrote:
> > Hi Folks,
> > I have a problem with remote access to my EPICS pvagw using sshuttle as tunnel into my lab network.
> > If I enable on the gateway the debug output, I see the request I send from home and that it gets processed correctly by the gateway.
> > It ask the IOC for the PV and sends the answer correctly back to my entry host. But on the client side at home I get a timeout.
> > If I uase the ca protocol over sshuttle to another ioc running in the lab network everything works correctly.
> > Does anybody know ho to get that combination running?
> I had not heard of "sshuttle" before.  At a guess, port numbers are probably being remapped.  PVA does not handle this well.
> Personally, I can usually make due with forwarding only TCP and making use of EPICS_PVA_NAME_SERVER.  For simple situations, I can point the client directly at a single IOC.  For more complex situations, I can configure a p4p.gw to listen on TCP port 15064. Forward that port with SSH.  Then point my client at "EPICS_PVA_NAME_SERVER=127.0.0.1:15064".
BEGIN:VCARD
VERSION:3.0
EMAIL;TYPE:j.dreyer at hzdr.de
FN:Jörn Dreyer
N:Dreyer;Jörn;;;
ORG:Helmholtz - Zentrum Dresden- Rossendorf;FWKX
TEL;TYPE=WORK:+0493502603263
TITLE:Dr.
UID:c191707b-eb41-4699-bb8d-a5ef050ab4aa
X-KADDRESSBOOK-MailPreferedFormatting:TEXT
END:VCARD
Re: PVA via sshuttel tunnel Ralph Lange via Tech-talk
PVA via sshuttel tunnel Jörn Dreyer via Tech-talk
Re: PVA via sshuttel tunnel Michael Davidsaver via Tech-talk
Prev: What are use cases for E-Traveler Wang, Lin via Tech-talk
Next: Re: PVA via sshuttel tunnel Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: PVA via sshuttel tunnel Michael Davidsaver via Tech-talk
ANJ, 10 Apr 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
