1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: PVA via sshuttel tunnel
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Fri, 10 Apr 2026 09:38:22 +0200
On Fri, 10 Apr 2026 at 08:58, Jörn Dreyer via Tech-talk <tech-talk at aps.anl.gov> wrote:
I choose sshuttle to connect phoebus and my IOC because I have multiple IOC's I want to access and I am not allowed to run a gateway on our login node.
You don't have to run the gateway on the login node.
The whole power (and danger) of SSH tunneling is that you can forward the tunnel to a different machine on the other side.
The normal setup for CA or PVA through SSH tunneling is to have a gateway running e.g. on port 15064 of some "gw" machine (must be reachable from the login node - which is often called "jump host") and then set up a tunnel as, e.g.
This creates a tunnel from localhost:12345 to gw:15064. Setting your EPICS_PVA_NAME_SERVERS variable or preference to localhost:12345 will reach your gateway.
Cheers,
~Ralph
PVA via sshuttel tunnel Jörn Dreyer via Tech-talk
Re: PVA via sshuttel tunnel Michael Davidsaver via Tech-talk
Re: PVA via sshuttel tunnel Jörn Dreyer via Tech-talk
Prev: Re: PVA via sshuttel tunnel Jörn Dreyer via Tech-talk
Next: Re: StreamDevice error involving PCRE library in Debian Trixie Gerrit Kühn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: epics-ioc-runner: A lightweight systemd & procServ IOC Han Lee via Tech-talk
ANJ, 10 Apr 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
