1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Simulate an existing IOC with a python IOC
From: Érico Nogueira Rolim via Tech-talk <tech-talk at aps.anl.gov>
To: Graeme Winter <gw363 at cornell.edu>
Cc: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Wed, 22 Apr 2026 16:38:55 +0000
Hi Graeme!
On 4/22/26 07:40, Graeme Winter via Tech-talk wrote:
> It could work - in principle a quick dbl in the running IOC would be enough to cobble together what I was after
If remote access is needed, I believe pvlist or reccaster could provide
basically the same list.
> However
> # Unsupported record type asyn
> … busy, calc, calcout etc.
I think it should be reasonably simple to implement busy and calc yourself.
asyn wouldn't be available in a softIoc, so it really should be omitted.
For usual cases, I don't believe there are calcout fields which should
be exposed to GUIs or similar, so it could be skipped as well.
> May be more of a problem - I will see how far I can get with this
> It may be I need to provide a mocking layer one layer above the EPICS to get this done…
All the above said, I think there could be an alternative implementation
of ioc-clone. If you only access the VAL field of any record you're
using, that can be cleanly implemented for all record types by querying
the PVs with DBR_CTRL_*, and creating a record with the corresponding
type and configuration (ai for DOUBLE, longin for LONG, mbbi for ENUM,
etc). This would avoid depending on knowledge of specific records,
including any custom ones.
I'm not sure this solution wouldn't have other issues, and using only
VAL might not be a common situation.
> Thanks Graeme
>> On 21 Apr 2026, at 14:41, Ralph Lange via Tech-talk <tech-talk at aps.anl.gov> wrote:
>> But does working from files fulfill your original requirement to "interrogate a running IOC"?
>> Cheers,
>> ~Ralph
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Simulate an existing IOC with a python IOC Graeme Winter via Tech-talk
Re: Simulate an existing IOC with a python IOC Michael Davidsaver via Tech-talk
Re: Simulate an existing IOC with a python IOC Graeme Winter via Tech-talk
Re: Simulate an existing IOC with a python IOC Ralph Lange via Tech-talk
Prev: Re: Access Security Config File (ACF) size? Johnson, Andrew N. via Tech-talk
Next: Re: Access Security Config File (ACF) size? Érico Nogueira Rolim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Simulate an existing IOC with a python IOC Graeme Winter via Tech-talk
Next: Re: Simulate an existing IOC with a python IOC Ralph Lange via Tech-talk
ANJ, 23 Apr 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
