1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Access Security Config File (ACF) size?
From: Érico Nogueira Rolim via Tech-talk <tech-talk at aps.anl.gov>
To: David Bracey <dbracey at fnal.gov>, "Johnson, Andrew N." <anj at anl.gov>, Anders Lindh Olsson <anders.lindholsson at ess.eu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 22 Apr 2026 16:49:11 +0000
In whichever situation you end up, it sounds like writing to the ASG field of multiple records will be needed to choose what configuration to apply to that IOC / part of that IOC.
I've used https://github.com/brunoseivam/retools for this, where I write to ASG after iocInit using some rules. After rebooting ~150 IOCs, I will get one IOC deadlocking in rePutField, which I need to investigate and open a bug report for, but besides that, it works fine.
What other solutions are used for this purpose in labs making heavy use of access security?
On 4/22/26 13:09, David Bracey via Tech-talk wrote:
>> If you’re going to give each record its own ASG you would need to have a separate file for each IOC …
That was just an extreme example for the sake of discussion – I’m sure we won’t do that …
>> I assume you know that rules can use PV values to control whether they are enabled or not; that’s how
>> you should try to configure dynamic access changes if possible, reloading a large ACF isn’t something I’d want to be doing very often.
That seems pretty promising, thanks!
Date: Wednesday, April 22, 2026 at 11:01
 AM
To: David Bracey <dbracey at fnal.gov>, Anders Lindh Olsson <anders.lindholsson at ess.eu>, tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Hi David,
We try to share ACF files amongst all the IOCs that implement a subsystem, and as you suggest we do load them from an NFS share. For example all our vacuum IOCs in the storage ring would load the same file, since the same people need the same access rights to all of those IOCs. We currently have around 70 ACF files for the whole of the APS accelerator (~2,300,000 records), although many of the older IOCs don’t enable access security.
The only limits for the IOC on the size of the file are going to be how much memory it takes to store the data, and how long it takes to parse it (I’m not sure if the server disables I/O or new connections while it’s reloading the file). If you’re going to give each record its own ASG you would need to have a separate file for each IOC instead of sharing them, just to minimize how long a reload takes. There is a hash table in asLib used for doing lookups by name, but it looks like that currently gets initialized with only 256 buckets. For performance you would want to increase that if you’re going to load more than about a thousand named groups (UAG+HAG+ASG).
I assume you know that rules can use PV values to control whether they are enabled or not; that’s how you should try to configure dynamic access changes if possible, reloading a large ACF isn’t something I’d want to be doing very often.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 4/22/26, 10:17 AM, "Tech-talk" <tech-talk-bounces at aps.anl.gov> wrote:
It seems to me that managing the ACF (or ACFs) is straightforward, since these can be centrally located (on some network share, where IOC’s can read them).
The hard part is the association of ASG to DB record, since these are declared with the record instances on the IOC.  Since these are scattered at your edge, they are more difficult to manage or audit.
I would think a strategy that required the ASG <-> record association to change as rarely as possible, and instead favored modifying the ACF(s) and telling IOC’s to reload would be desired.
From: Anders Lindh Olsson <anders.lindholsson at ess.eu>
Date: Wednesday, April 22, 2026 at 9:43
 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>, David Bracey <dbracey at fnal.gov>
[EXTERNAL] – This message is from an external sender
Hi Dave,
We use a singular ACF file at ESS, and we currently have around ~10 M records in production. It has not really been a problem thus far, but we also do not (yet?) have many conditionals in the file.
When we decided on the approach, we weighed between per-IOC and global and centralised. One of the main concerns for per-IOC was traceability - doing pvget MY-PV.ASG will not be very helpful.
Cheers
A
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of David Bracey via Tech-talk <tech-talk at aps.anl.gov>
Sent: 22 April 2026 16:19
Subject: Access Security Config File (ACF) size?
Does anyone have a feel for how large an ACF could be without becoming problematic?
Considering an extreme example, if one had ~100000 PVs, and one defined an ASG for each PV, would that be a problem?
How big do ACF’s get in the wild?
Are there strategies for using multiple ACF’s?
  • Dave Bracey, Fermilab
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Access Security Config File (ACF) size? Ralph Lange via Tech-talk
Access Security Config File (ACF) size? David Bracey via Tech-talk
Re: Access Security Config File (ACF) size? Anders Lindh Olsson via Tech-talk
Re: Access Security Config File (ACF) size? David Bracey via Tech-talk
Re: Access Security Config File (ACF) size? Johnson, Andrew N. via Tech-talk
Prev: Re: Simulate an existing IOC with a python IOC Érico Nogueira Rolim via Tech-talk
Next: PVXS and CA Put benchmark Bernardo Brotas Carvalho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Access Security Config File (ACF) size? Johnson, Andrew N. via Tech-talk
Next: Re: Access Security Config File (ACF) size? Ralph Lange via Tech-talk
ANJ, 23 Apr 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
