1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Access Security Config File (ACF) size?
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Thu, 23 Apr 2026 11:22:58 +0200
Interesting.
I would never consider changing the ASG of a record...
I am with team Andrew on this: Keep the ASG fixed and use the CALC-like expressions engine inside Access Security to dynamically change the rules (behavior) of the group instead of changing the records that it applies to. The CALC-mechanism is less invasive, very flexible and uses monitors, so changes are applied automatically as the controlling PV changes value.
Cheers,
~Ralph
Re: Access Security Config File (ACF) size? Érico Nogueira Rolim via Tech-talk
Access Security Config File (ACF) size? David Bracey via Tech-talk
Re: Access Security Config File (ACF) size? Anders Lindh Olsson via Tech-talk
Re: Access Security Config File (ACF) size? David Bracey via Tech-talk
Re: Access Security Config File (ACF) size? Johnson, Andrew N. via Tech-talk
Prev: Re: Simulate an existing IOC with a python IOC Ralph Lange via Tech-talk
Next: Re: PVXS and CA Put benchmark Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Access Security Config File (ACF) size? Érico Nogueira Rolim via Tech-talk
Next: Re: Access Security Config File (ACF) size? Érico Nogueira Rolim via Tech-talk
ANJ, 23 Apr 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
