1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: BO which should switch to 1 whenever processed
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Fri, 24 Apr 2026 16:26:05 +0200
On Thu, 23 Apr 2026 at 16:02, Pearson, Matthew via Tech-talk <tech-talk at aps.anl.gov> wrote:
You may have to have that extra record, although there’s usually a few ways of doing this.
Well, DOL just needs to be a link.
That link could point to an unused field of the same bo record, which is set to 1 (e.g., EVNT). If the locking gets in the way, make it a CA link.
(Also make sure to document this properly, so it doesn't get removed by a well-meaning colleague later on.)
Cheers,
~Ralph
BO which should switch to 1 whenever processed Majer Karel via Tech-talk
RE: BO which should switch to 1 whenever processed Pearson, Matthew via Tech-talk
Prev: Re: Access Security Config File (ACF) size? Érico Nogueira Rolim via Tech-talk
Next: CPU usage and response time of EPICS Channel Access responses Wells, Alex (DLSLtd,RAL,TEC) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: RE: BO which should switch to 1 whenever processed Pearson, Matthew via Tech-talk
Next: Re: BO which should switch to 1 whenever processed Hu, Yong via Tech-talk
ANJ, 29 Apr 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
