1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Phoebus image frame rate
From: Jure Varlec via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Tue, 12 May 2026 16:50:19 +0200
Dear all,
I have made a Phoebus display consisting of nothing but an image widget. All axes off, interpolation disabled. A color video streamed over PVA is unpleasant to look at, I'd say it has about 5 FPS, maybe. The IOC is on the same machine, so there's plenty of "network" bandwidth. I have tried pvmonitor and c2dataviewer, both had no issues streaming at 30 FPS. I've tried Phoebus 4.7.3 and 5.0.0.
I'm aware of Phoebus' delay settings, which have been set to:
org.csstudio.display.builder.representation/image_update_delay=10
org.csstudio.display.builder.representation/update_delay=10
No effect. Actually, there is an effect: if I set the image update delay to 1000 ms, I get 1 FPS as expected. But reducing it below ~200 ms doesn't increase it beyond ~5 FPS.
I consulted both artificial and natural intelligence and, after the AI had a look at verbose Phoebus logs and results of Java async-profiler, both agreed that the culprit is probably image decoding in Phoebus. I find that hard to believe. I reduced image resolution to 640x480 (the camera I use refused to go lower than that) and frame rate stayed at about 5 FPS. That makes no sense to me. I'd rather believe that there's some setting I don't know about.
Is there? Please?
Jure
RE: [EXTERNAL] Phoebus image frame rate Pearson, Matthew via Tech-talk
Prev: Re: PVA custom structs Sky Brewer via Tech-talk
Next: RE: [EXTERNAL] Phoebus image frame rate Pearson, Matthew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Prev: VisualDCT (VDCT) bugfix release 2.8.4 Ralph Lange via Tech-talk
ANJ, 12 May 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
