1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: PVA custom structs
From: Sky Brewer via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, "junkes at fhi-berlin.mpg.de" <junkes at fhi-berlin.mpg.de>
Cc: "Shankar, Murali" <mshankar at slac.stanford.edu>
Date: Tue, 12 May 2026 09:23:56 +0000
Hi Heinz,
As other have mentioned for custom structs the Archiver expects:
NTScalar
where the value field is a structure. In particular timeStamp structure (including userTag) and alarms structure.  This is probably not well documented...
Maybe this is a type to add to the normative types documentation? NTStructure? Which actually could supersum NTScalar, NTScalarArray, NTEnum?
Note to retrieve the json api does unpack the data and return a sort of standard json output. I would like to upstream that from the Archiver Appliance to core-pva.
Hope that helps,
Sky
Re: PVA custom structs Sky Brewer via Tech-talk
Prev: Re: Understanding alarms, alarm server and notification usage in other facilities Michael Davidsaver via Tech-talk
Next: Phoebus image frame rate Jure Varlec via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: PVA custom structs Ralph Lange via Tech-talk
Next: Re: PVA custom structs Sky Brewer via Tech-talk
ANJ, 18 May 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
