1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: [EXTERNAL] PyDM Write Widgets Do Not Honor PVA ACF Permission Rules
From: "Kasemir, Kay via Tech-talk" <tech-talk at aps.anl.gov>
To: "lvhh at sari.ac.cn" <lvhh at sari.ac.cn>, tech-talk <tech-talk at aps.anl.gov>
Date: Thu, 14 May 2026 13:51:44 +0000
At this time, the PVA protocol doesn’t support access information.
In other words, the protocol doesn’t tell you ahead of time if you have write access.
If you can’t write, you only notice that once you try to write and then you get an error reply.
See https://github.com/epics-docs/epics-docs/pull/140 for the ongoing effort to add permission into to the protocol.
-Kay
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of lvhh--- via Tech-talk <tech-talk at aps.anl.gov>
Date: Wednesday, May 13, 2026 at 10:19 PM
To: tech-talk <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] PyDM Write Widgets Do Not Honor PVA ACF Permission Rules
This Message Is From an External Sender
This email was sent from a non-ORNL address. If suspicious, use the Report Phish button in Outlook.
Hi all,
We develop OPIs using PyDM. All functions work properly when using the CA protocol. However, we have encountered a permission‑enforcement problem under the PVA protocol.
Specifically, PyDM write‑enabled widgets fail to comply with access permission rules defined in the PVA ACF security file. Even though write access is explicitly denied in the ACF configuration, value writing is still allowed on the PyDM GUI interface.
Thanks for your reply.
Huihui
lvhh at sari.ac.cn
Re: [EXTERNAL] PyDM Write Widgets Do Not Honor PVA ACF Permission Rules André Favoto via Tech-talk
PyDM Write Widgets Do Not Honor PVA ACF Permission Rules lvhh--- via Tech-talk
Prev: PyDM Write Widgets Do Not Honor PVA ACF Permission Rules lvhh--- via Tech-talk
Next: Re: [EXTERNAL] PyDM Write Widgets Do Not Honor PVA ACF Permission Rules André Favoto via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
ANJ, 15 May 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
