1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: [EXTERNAL] PyDM Write Widgets Do Not Honor PVA ACF Permission Rules
From: André Favoto via Tech-talk <tech-talk at aps.anl.gov>
To: "Kasemir, Kay" <kasemirk at ornl.gov>, "lvhh at sari.ac.cn" <lvhh at sari.ac.cn>, tech-talk <tech-talk at aps.anl.gov>
Date: Fri, 15 May 2026 07:50:19 +0000
  • value writing is still allowed on the PyDM GUI interface.
Does this mean the widget is only "enabled" on the UI level, but the actual PV does not update if you try to write, or are you actually seeing the PV updating on a separate terminal?
For the reason explained on previous answer, and being pyDM a desktop app, I would expect the first. If that's not it, could you share details on your ACF settings?
I'm particularly interested in these types of GUI concerns at the moment for WEISS.
Re: [EXTERNAL] PyDM Write Widgets Do Not Honor PVA ACF Permission Rules Kasemir, Kay via Tech-talk
PyDM Write Widgets Do Not Honor PVA ACF Permission Rules lvhh--- via Tech-talk
Prev: Re: [EXTERNAL] PyDM Write Widgets Do Not Honor PVA ACF Permission Rules Kasemir, Kay via Tech-talk
Next: Re: [EXTERNAL] PyDM Write Widgets Do Not Honor PVA ACF Permission Rules Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
ANJ, 15 May 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
