1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: EPICS modulle for Piezosystem Jena's piezo controller NV 40/1 CLE
From: Torsten Bögershausen via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>, LiangChih Chiang <yehnan174 at gmail.com>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 19 May 2026 15:16:00 +0200
Yes,
that may have one disadvantage:
When the controller is not online, while the
constructor is run, this is lost.
It may need a better/more robust solution.
Either to introduce a firstPoll() method which is called
when the connection is established/re-estabished.
Or an output-record, which is processed, when the connection
status changes. I am not so familar with asyn, here.
Or: A stream device based output record ;-)
We recently learned that stream device has some support
for connecting/reconnecting. (Thanks, Dirk)
On 2026-05-19 14:52, Mark Rivers wrote:
On May 18, 2026, at 8:47 PM, LiangChih Chiang <yehnan174 at gmail.com> wrote:
To operate the controller remotely,
there is a command "i1" to "activate remote control".
Which part of Model 3 motor driver code should I put this activation command?
If you always want it in that mode then you can put it in the constructor.
EPICS modulle for Piezosystem Jena's piezo controller NV 40/1 CLE LiangChih Chiang via Tech-talk
Re: EPICS modulle for Piezosystem Jena's piezo controller NV 40/1 CLE Torsten Bögershausen via Tech-talk
Re: EPICS modulle for Piezosystem Jena's piezo controller NV 40/1 CLE LiangChih Chiang via Tech-talk
Re: EPICS modulle for Piezosystem Jena's piezo controller NV 40/1 CLE Mark Rivers via Tech-talk
RE: EPICS modulle for Piezosystem Jena's piezo controller NV 40/1 CLE Pearson, Matthew via Tech-talk
Prev: Re: EPICS modulle for Piezosystem Jena's piezo controller NV 40/1 CLE Mark Rivers via Tech-talk
Next: LakeShore 335 problem Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: Configuring CA Compatibility in PVA Gateway for Mixed CA/PVA PV Access lvhh--- via Tech-talk
ANJ, 19 May 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
