1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: RE: Motor: Experience with KOHZU ?
From: "Goetze, Kurt via Tech-talk" <tech-talk at aps.anl.gov>
To: Torsten Bögershausen <tboegi at edom.se>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 4 Jun 2026 15:12:03 +0000
Hi Torsten,
In my experience Kohzu has been very good.  Their stages and precision machinery have a really good reputation and are used extensively here at the APS.  For motors, Kohzu usually uses hardware from Oriental Motor.  We've only used steppers.  Kohzu packages 2-phase and 5-phase motor drivers using compatible Oriental Motor equipment.  These chassis are built with APS connectors and pinouts, and typically run with step/dir.  This equipment has been reliable.
Kohzu's tech support is good and we have a local rep who is really knowledgeable.
I can put you in touch with him and/or other local experts if you want to follow up with me.
Take care,
Kurt
-----Original Message-----
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Torsten Bögershausen via Tech-talk
Sent: Thursday, June 4, 2026 9:24 AM
To: tech-talk at aps.anl.gov
Subject: Motor: Experience with KOHZU ?
Hej motor experts,
(The question came up here)
does anyone have experience with KOHZU motors ?
Good or not so good ?
Answers are welcome via
reply (only to me, if you want to share something in private) or reply-all (if it can be shared officially)
Thanks
/Torsten
Re: Motor: Experience with KOHZU ? Torsten Bögershausen via Tech-talk
Prev: Re: Motor: Experience with KOHZU ? Mark Rivers via Tech-talk
Next: Re: Motor: Experience with KOHZU ? Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
ANJ, 04 Jun 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
