1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Motor: Experience with KOHZU ?
From: Torsten Bögershausen via Tech-talk <tech-talk at aps.anl.gov>
To: "Goetze, Kurt" <goetze at anl.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 4 Jun 2026 17:47:53 +0200
Thanks for the fast response.
I'll send that to the motion controll engineer,
who raised the question.
The question aimed to ask about
"Kohzu standard stages setups, like goniometer stage+motor+encoder+switches"
Thanks again,
/Torsten
On 2026-06-04 17:12, Goetze, Kurt wrote:
In my experience Kohzu has been very good.  Their stages and precision machinery have a really good reputation and are used extensively here at the APS.  For motors, Kohzu usually uses hardware from Oriental Motor.  We've only used steppers.  Kohzu packages 2-phase and 5-phase motor drivers using compatible Oriental Motor equipment.  These chassis are built with APS connectors and pinouts, and typically run with step/dir.  This equipment has been reliable.
Kohzu's tech support is good and we have a local rep who is really knowledgeable.
I can put you in touch with him and/or other local experts if you want to follow up with me.
Take care,
Kurt
Motor: Experience with KOHZU ? Torsten Bögershausen via Tech-talk
RE: Motor: Experience with KOHZU ? Goetze, Kurt via Tech-talk
Prev: RE: Motor: Experience with KOHZU ? Goetze, Kurt via Tech-talk
Next: CS-Studio rules on X/Y Plot Pearson, Matthew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: Re: Motor: Experience with KOHZU ? Mark Rivers via Tech-talk
ANJ, 04 Jun 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
