1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Gamma DIGITEL MPCq: mismatch after 0 bytes ""
From: LiangChih Chiang via Tech-talk <tech-talk at aps.anl.gov>
To: "J. Lewis Muir" <jlmuir at imca-cat.org>
Cc: EPICS Tech-Talk <tech-talk at aps.anl.gov>
Date: Thu, 9 Jul 2026 08:13:23 +0800
I encounter the same pattern of errors.
Sometimes it happened, sometimes it didn't.
Some devices happened more frequently than others.
Don't kno why.
My colleague also wrote our own EPICS module(use streamdevice).
It also will generate the same pattern of errors.
On Thu, Jul 9, 2026 at 7:22 AM J. Lewis Muir via Tech-talk <tech-talk at aps.anl.gov> wrote:
Hi, Tech-Talkers!
I'm using the driver at
  github.com/epics-modules/ip/blob/master/ipApp/Db/MPC_Ethernet.template
to control Gamma DIGITEL MPCq devices connected via Ethernet, and it
mostly works, but I sometimes get errors on the IOC console like the
following (it seems to happen for all of them, so not limited to just
one device), and I'm wondering, does anyone know what might be going
wrong and how to fix it?
2026/07/08 11:50:09.782653 GAMMA5 17ida:ip9:CUR: Input ">OK 00 1.1E-04 AMPS<0d><0d><0a>>..."
2026/07/08 11:50:09.782668 GAMMA5 17ida:ip9:CUR: mismatch after 0 bytes ""
2026/07/08 11:50:09.782674 GAMMA5 17ida:ip9:CUR: got ">OK 00 1.1..." where "OK 00 " was expected
This same pattern of errors occurs for various values (e.g., CUR,
GAUTOS, PRES, SIZE, VOLT, and STAT).
Thanks!
Lewis
Gamma DIGITEL MPCq: mismatch after 0 bytes "" J. Lewis Muir via Tech-talk
Prev: Gamma DIGITEL MPCq: mismatch after 0 bytes "" J. Lewis Muir via Tech-talk
Next: Re: Gamma DIGITEL MPCq: mismatch after 0 bytes "" Maren Purves via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
ANJ, 08 Jul 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
