1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: [EXTERNAL] Gamma DIGITEL MPCq: mismatch after 0 bytes ""
From: "Baily, Scott A via Tech-talk" <tech-talk at aps.anl.gov>
To: "J. Lewis Muir" <jlmuir at imca-cat.org>, EPICS Tech-Talk <tech-talk at aps.anl.gov>
Date: Thu, 9 Jul 2026 01:46:18 +0000
The issue is the prompt. I can think of several ways to handle this, I just changed the in termination to be /r/r/n>   The prompt is sent separately to technically it’s not part of the termination, but it is always sent after the response.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of J. Lewis Muir via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, 08 July 2026 17:22:18
To: EPICS Tech-Talk <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] Gamma DIGITEL MPCq: mismatch after 0 bytes ""
Hi, Tech-Talkers!
I'm using the driver at
  https://urldefense.com/v3/__http://github.com/epics-modules/ip/blob/master/ipApp/Db/MPC_Ethernet.template__;!!Bt8fGhp8LhKGRg!BmWtxEb5lgCs6dhQy2XSk82mrXDHxsxPCPtxPTGc_8xz2T6kAUg6_qheSTOSsqA3Jj4VDCtPHtEwLHJkB2nHQg$
to control Gamma DIGITEL MPCq devices connected via Ethernet, and it
mostly works, but I sometimes get errors on the IOC console like the
following (it seems to happen for all of them, so not limited to just
one device), and I'm wondering, does anyone know what might be going
wrong and how to fix it?
2026/07/08 11:50:09.782653 GAMMA5 17ida:ip9:CUR: Input ">OK 00 1.1E-04 AMPS<0d><0d><0a>>..."
2026/07/08 11:50:09.782668 GAMMA5 17ida:ip9:CUR: mismatch after 0 bytes ""
2026/07/08 11:50:09.782674 GAMMA5 17ida:ip9:CUR: got ">OK 00 1.1..." where "OK 00 " was expected
This same pattern of errors occurs for various values (e.g., CUR,
GAUTOS, PRES, SIZE, VOLT, and STAT).
Thanks!
Lewis
Re: [EXTERNAL] Gamma DIGITEL MPCq: mismatch after 0 bytes "" Abdalla Ahmad via Tech-talk
Gamma DIGITEL MPCq: mismatch after 0 bytes "" J. Lewis Muir via Tech-talk
Prev: Re: Gamma DIGITEL MPCq: mismatch after 0 bytes "" Maren Purves via Tech-talk
Next: Re: [EXTERNAL] Gamma DIGITEL MPCq: mismatch after 0 bytes "" Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
ANJ, 09 Jul 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
