1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: PVA OUT Links in EPICS:
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: "Donadio, Marcio Paduan" <marcio at slac.stanford.edu>
Cc: Varuna Crishan Meddage <vmeddage at fnal.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 13 Jul 2026 20:11:59 -0700
On 7/13/26 3:07 PM, Donadio, Marcio Paduan via Tech-talk wrote:
I can think of another idea to add: set field(PINI, “RUNNING”) instead of “YES”.
"RUNNING" refers to the record scanning threads of the local database.  It is not a statement about remote PVA/CA links.
You may be thinking of a recent (unreleased) change which ensures that CA links to local records will be connected by RUNNING.  Sadly the reality of an unreliable world (network, power, etc.) prevents such guarantees from being made for remote links ;)
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Varuna Crishan Meddage via Tech-talk <tech-talk at aps.anl.gov>
Date: Tuesday, June 9, 2026 at 09:30
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Thank you.
From: Michael Davidsaver <mdavidsaver at gmail.com>
Sent: Monday, June 8, 2026 7:36 PM
To: Varuna Crishan Meddage <vmeddage at fnal.gov>
[EXTERNAL] – This message is from an external sender
On 6/8/26 4:13 PM, Varuna Crishan Meddage via Tech-talk wrote:
I tried different tricks for example setting field(VAL, "0") and field(PINI, "YES"), but none of them was successful.
I should also note that setting PINI to YES will leave this record with a INVALID LINK alarm as the PVA link is unlikely to be connected by the time of the initial process scan.
Depending on your desired reconnect behavior, you may wish to investigate the "retry" link option.
retry. For an output link, and true (not default), then the most recent incomplete PUT will be re-tried when the target PV (re)connects.
PVA OUT Links in EPICS: Varuna Crishan Meddage via Tech-talk
Re: PVA OUT Links in EPICS: Michael Davidsaver via Tech-talk
Re: PVA OUT Links in EPICS: Varuna Crishan Meddage via Tech-talk
Re: PVA OUT Links in EPICS: Donadio, Marcio Paduan via Tech-talk
Prev: Re: PVA OUT Links in EPICS: Donadio, Marcio Paduan via Tech-talk
Next: EPICS Integration With AVEVA PI using PI Web API Josh West via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Next: Re: PVA OUT Links in EPICS: Ralph Lange via Tech-talk
ANJ, 14 Jul 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
