1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: IOC build to generate single DB file from two substitutions on single template file
From: David Bracey via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 24 Jul 2026 15:26:14 +0000
I am trying to:
  1. Start from a single template file with a single record instance
  2. Apply two different substitution files
  3. Result in a single DB file with a single record instance (with substitutions performed)
So what I’m looking for is either a two-pass substitution, or having one subs file include the other, but I don’t think those things exist.
The purpose of this is to be able to create a number of instances of IOCs, where many of the substitutions are common to all, but some are per-instance.
Dave Bracey
Fermi National Accelerator Laboratory
Re: IOC build to generate single DB file from two substitutions on single template file David Bracey via Tech-talk
Prev: Re: Modbus Module issue Mark Rivers via Tech-talk
Next: Re: IOC build to generate single DB file from two substitutions on single template file David Bracey via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Prev: Re: Create record name manifest during build Anders Lindh Olsson via Tech-talk
ANJ, 24 Jul 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
