1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: IOC build to generate single DB file from two substitutions on single template file
From: David Bracey via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 24 Jul 2026 15:52:30 +0000
And with all the substitutions done at build time - none at run time via dbLoadRecords, etc.
Date: Friday, July 24, 2026 at 10:26 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: IOC build to generate single DB file from two substitutions on single template file
I am trying to:
So what I’m looking for is either a two-pass substitution, or having one subs file include the other, but I don’t think those things exist.
The purpose of this is to be able to create a number of instances of IOCs, where many of the substitutions are common to all, but some are per-instance.
Dave Bracey
Fermi National Accelerator Laboratory
Re: IOC build to generate single DB file from two substitutions on single template file Johnson, Andrew N. via Tech-talk
Re: IOC build to generate single DB file from two substitutions on single template file Michael Davidsaver via Tech-talk
IOC build to generate single DB file from two substitutions on single template file David Bracey via Tech-talk
Prev: IOC build to generate single DB file from two substitutions on single template file David Bracey via Tech-talk
Next: Re: IOC build to generate single DB file from two substitutions on single template file Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
ANJ, 24 Jul 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
