1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: IOCs - What are the built-in device types?
From: "Donadio, Marcio Paduan via Tech-talk" <tech-talk at aps.anl.gov>
To: "Johnson, Andrew N." <anj at anl.gov>, David Bracey <dbracey at fnal.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 28 Jul 2026 17:27:52 +0000
I’ve been incentivizing my team to add documentation or test code for the pull requests when it makes sense. Maybe we could request this from EPICS pull request authors?
Cheers,
Marcio Donadio
Embedded Systems Engineer | TID-ID-CSE
SLAC National Accelerator Laboratory
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Johnson, Andrew N. via Tech-talk <tech-talk at aps.anl.gov>
Date: Wednesday, June 17, 2026 at 18:42
To: David Bracey <dbracey at fnal.gov>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Hi Dave,
The published output from my pull request documenting the built-in device support can be found here, beware any AI hallucinations or dragons that may be present. Review comments and suggestions can go here if you have any.
Hope it helps!
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 6/17/26, 11:14 AM, "Tech-talk" <tech-talk-bounces at aps.anl.gov> wrote:
Hi Dave,
Great question, unfortunate answer: The current documentation doesn’t really cover those other DTYPs. Many of the record types have some documentation on their own soft and raw soft channel support, and there were entries in the Release Notes for some of the newer device supports that were integrated. The list of device support layers provided by Base can be found in the dbd/devSoft.dbd file of any EPICS 7 release after building, and it’s worth doing a Google search for any specific layer you’re interested in, but you might end up having to read the source to get some specific details at the moment (or ask here).
I may follow up with something written by Claude Code, which I have asked to fill in those gaps.
- Andrew
On 6/17/26, 9:44 AM, "Tech-talk" <tech-talk-bounces at aps.anl.gov> wrote:
There are apparently built-in device types that provide various useful data sources:
  #  get the current time-of-day
  field(DTYP, "Soft Timestamp")
  field(INP,  "@%m/%d/%Y %H:%M:%S%z")
  # get the specified environment variable
  field(DTYP, "getenv")
  field(INP, "@ENGINEER")
Where can I find documentation of these built-in DTYP's?
Re: IOCs - What are the built-in device types? Johnson, Andrew N. via Tech-talk
IOCs - What are the built-in device types? David Bracey via Tech-talk
Prev: Re: Window build error - can find script. [SEC=OFFICIAL] Ralph Lange via Tech-talk
Next: Re: IOCs - What are the built-in device types? Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: IOCs - What are the built-in device types? Johnson, Andrew N. via Tech-talk
ANJ, 28 Jul 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
