1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: RE: Java PVA client: connect directly to known IOC endpoint without any search (no UDP multicast/unicast, no TCP directed search)
From: Usharani Kandula via Tech-talk <tech-talk at aps.anl.gov>
To: "greg at slac.stanford.edu" <greg at slac.stanford.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 25 Aug 2026 19:15:29 +0000
Hello Greg,
Thanks for the suggestion.
I double-checked the Java stack I’m using in my first trial (`org.epics:epics-pvaclient:4.3.2` with `epics-pvaccess:5.1.4-j8` and `epics-pvdata:6.1.4-j8`). I wasn’t able to find any obvious NTURI/URI-based direct-connect support in these versions (no `NTURI` references in the sources jars, and no `pva://` / URI parsing in the `PvaClient` APIs).
Could you please point me to the exact example/API you had in mind?
- Is there a specific class/method in `pvAccessJava`/`pvaClientJava` that accepts a URI like `pva://host:port/pvName`?
- Or is the NTURI example you mentioned intended for a different workflow (e.g., RPC services that accept an NTURI payload), rather than for client transport connection setup?
If you can share a link to the Normative Types NTURI example section (or a short code snippet), I can try it directly.
Best regards,
Usha
Sent: Tuesday, August 4, 2026 10:59 AM
To: tech-talk at aps.anl.gov
Subject: Java PVA client: connect directly to known IOC endpoint without any search (no UDP multicast/unicast, no TCP directed search)
Hello Team,
I’m looking for guidance on a Java PVA client use case where I already know the IOC endpoint for a PV (resolved via an internal lookup/database), and I want to connect directly to that IOC and read the PV without performing any PVA search.
Goal / Requirement
Given:
- PV name (example: `ABC:TEMP`)
- Known IOC endpoint (example: `127.0.0.1:5075`)
I want:
- No UDP multicast search
- No UDP unicast search
- No TCP directed search (i.e., avoid the `EPICS_PVA_NAME_SERVERS` search step)
- Instead: direct TCP connect + CreateChannel + read
In other words, since my internal lookup already tells me where the PV lives, I want to avoid asking the IOC again “do you have this PV?”
What I tried
1) Standard configuration to disable multicast/broadcast
I can disable multicast/broadcast discovery via:
EPICS_PVA_AUTO_ADDR_LIST=NO
EPICS_PVA_ADDR_LIST=
But the remaining supported approach is to use `EPICS_PVA_NAME_SERVERS=host:port`, which performs a directed TCP search. That still sends a search request to the IOC.
2) core-pva (Phoebus) low-level POC that skips search entirely
I built a proof-of-concept using `org.phoebus:core-pva:5.0.5` that successfully reads a PV from a known endpoint without any search.
High-level summary of the POC:
- Creates a `PVAClient`
- Creates a `PVAChannel`
- Unregisters it from search
- Creates a direct TCP handler to the known IOC endpoint
- Manually sets channel state to FOUND
- Registers the channel with the TCP handler (sends CreateChannelRequest)
- Connects and reads
This works (tested against a Python fake IOC), but it relies on package-private/internal APIs such as:
- `ClientTCPHandler`
- `ClientChannelState`
- `PVAChannel.setState()`
- `PVAChannel.registerWithServer()`
- `client.search.unregister()`
To access these, the POC code is placed in the same Java package as the library (`org.epics.pva.client`), which is not ideal for production.
Questions
1. Is there a supported/public Java API (in core-pva or elsewhere) to do a true direct connect to a known IOC endpoint without any search?
2. If not, would the community consider a change to core-pva to add a public API such as:
```java
PVAChannel connectDirect(String pvName, InetSocketAddress iocAddress)
that encapsulates the internal wiring currently required?
3. Are there protocol-level concerns with skipping search entirely (e.g., server GUID handling, channel lifecycle expectations) that would make this approach problematic?
Additional details
- Library: `org.phoebus:core-pva:5.0.5`
- Java: 21
- Current POC output shows successful connect/read and prints the returned `PVAStructure`.
Thanks in advance for any guidance.
Best regards,
Usharani
Fermi National Accelerator Laboratory
Java PVA client: connect directly to known IOC endpoint without any search (no UDP multicast/unicast, no TCP directed search) Usharani Kandula via Tech-talk
Prev: Recall: Java PVA client: connect directly to known IOC endpoint without any search (no UDP multicast/unicast, no TCP directed search) Usharani Kandula via Tech-talk
Next: Re: Phoebus on ARM64 Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: RE: Java PVA client: connect directly to known IOC endpoint without any search (no UDP multicast/unicast, no TCP directed search) Usharani Kandula via Tech-talk
Next: Support for MKS Microvision2 RGA? Ralph Lange via Tech-talk
ANJ, 08 Sep 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
