Hi Team,
I wanted to follow up on the question I shared earlier. When you have a chance, I would appreciate any guidance or feedback you may have.
Thank you for your time.
Best regards,
Uharani
Sent: Monday, August 24, 2026 9:52 AM
To: tech-talk at aps.anl.gov
Subject: RE: Java PVA client: connect directly to known IOC endpoint without any search (no UDP multicast/unicast, no TCP directed search)
Hello Greg,
Thanks for the suggestion.
I double-checked the Java stack I’m using in my first trial (`org.epics:epics-pvaclient:4.3.2` with `epics-pvaccess:5.1.4-j8` and `epics-pvdata:6.1.4-j8`). I wasn’t able to find any obvious NTURI/URI-based
direct-connect support in these versions (no `NTURI` references in the sources jars, and no `pva://` / URI parsing in the `PvaClient` APIs).
Could you please point me to the exact example/API you had in mind?
- Is there a specific class/method in `pvAccessJava`/`pvaClientJava` that accepts a URI like `pva://host:port/pvName`?
- Or is the NTURI example you mentioned intended for a different workflow (e.g., RPC services that accept an NTURI payload), rather than for client transport connection setup?
If you can share a link to the Normative Types NTURI example section (or a short code snippet), I can try it directly.
Best regards,
Usha
Sent: Tuesday, August 4, 2026 10:59 AM
Subject: Java PVA client: connect directly to known IOC endpoint without any search (no UDP multicast/unicast, no TCP directed search)
Hello Team,
I’m looking for guidance on a Java PVA client use case where I already know the IOC endpoint for a PV (resolved via an internal lookup/database), and I want to connect
directly to that IOC and read the PV without performing any PVA search.
Goal / Requirement
Given:
- PV name (example: `ABC:TEMP`)
- Known IOC endpoint (example: `127.0.0.1:5075`)
I want:
- No UDP multicast search
- No UDP unicast search
- No TCP directed search (i.e., avoid the `EPICS_PVA_NAME_SERVERS` search step)
- Instead: direct TCP connect + CreateChannel + read
In other words, since my internal lookup already tells me where the PV lives, I want to avoid asking the IOC again “do you have this PV?”
What I tried
1) Standard configuration to disable multicast/broadcast
I can disable multicast/broadcast discovery via:
EPICS_PVA_AUTO_ADDR_LIST=NO
EPICS_PVA_ADDR_LIST=
But the remaining supported approach is to use `EPICS_PVA_NAME_SERVERS=host:port`, which performs a directed TCP search. That still sends a search request to the IOC.
2) core-pva (Phoebus) low-level POC that skips search entirely
I built a proof-of-concept using `org.phoebus:core-pva:5.0.5` that successfully reads a PV from a known endpoint without any search.
High-level summary of the POC:
- Creates a `PVAClient`
- Creates a `PVAChannel`
- Unregisters it from search
- Creates a direct TCP handler to the known IOC endpoint
- Manually sets channel state to FOUND
- Registers the channel with the TCP handler (sends CreateChannelRequest)
- Connects and reads
This works (tested against a Python fake IOC), but it relies on package-private/internal APIs such as:
- `ClientTCPHandler`
- `ClientChannelState`
- `PVAChannel.setState()`
- `PVAChannel.registerWithServer()`
- `client.search.unregister()`
To access these, the POC code is placed in the same Java package as the library (`org.epics.pva.client`), which is not ideal for production.
Questions
1. Is there a supported/public Java API (in core-pva or elsewhere) to do a true direct connect to a known IOC endpoint without any search?
2. If not, would the community consider a change to core-pva to add a public API such as:
```java
PVAChannel connectDirect(String pvName, InetSocketAddress iocAddress)
that encapsulates the internal wiring currently required?
3. Are there protocol-level concerns with skipping search entirely (e.g., server GUID handling, channel lifecycle expectations) that would make this approach problematic?
Additional details
- Library: `org.phoebus:core-pva:5.0.5`
- Java: 21
- Current POC output shows successful connect/read and prints the returned `PVAStructure`.
Thanks in advance for any guidance.
Best regards,
Usharani
Fermi National Accelerator Laboratory
