1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Naming bits in an mbbiDirect record
From: André Favoto via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>, Ralph Lange <ralph.lange at gmx.de>
Date: Fri, 4 Sep 2026 09:03:51 +0000
I did open an issue some time ago requesting that feature: https://github.com/epics-base/epics-base/issues/846
It would be very convenient to have a way to set a label for each bit inside the record.
As a workaround, we have separate PVS like "NameBit1", "NameBit2", etc, which works, but it is as much of a pain as mapping individual bi records.
Having a binary PV for each bit kind of defeats the purpose of using mbbiDirect structure IMO.
There is, of course, the concern of having the individual bit severities that Ralph mentioned on the issue above.
But having one does not block the other, and I don't see how adding labels to the bits would change in any way the severity/alarm handling.
If one needs individual severities/alarms for each bit or combinations of them, then I agree that mapping to separate records is the correct approach.
Best Regards,
André Favoto
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
Sent: Friday, September 4, 2026 08:59
No, not inside the mbbiDirect.
To get the single bit description (and alarm severity/status, and value strings, ...) add a biRecord for each bit and point its input link to the appropriate bit field of the mbbiDirectRecord. If you make that input link CP or CPP, the single bit record will only process when the value of that bit changes.
Cheers,
~Ralph
Re: Naming bits in an mbbiDirect record Johnson, Andrew N. via Tech-talk
Naming bits in an mbbiDirect record William Badgett via Tech-talk
Re: Naming bits in an mbbiDirect record Ralph Lange via Tech-talk
Prev: Re: Naming bits in an mbbiDirect record Ralph Lange via Tech-talk
Next: Re: Naming bits in an mbbiDirect record Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
ANJ, 04 Sep 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
