Hello,
I am trying to access a USB based DSOs (Tektronics TDS 2014B or Agilent
DSO1024A) using Keysight/Agilent E5810B Ethernet gateway. My connection
string is as follows:
vxi11Configure("L2", "10.42.0.10", 0, "0.0",
"usb0[1689::872::C039225::0]", 0, 0)
However, on starting the IOC, I am getting following errors/warnings:
L2 vxiBusStatus error VXI: operation not supported
2026/09/16 16:14:42.685 L2 asynGpib:srqPoll srqStatus error error
There is no response from following record:
record (stringin, "$(P)$(DEVICE)IDN")
field (SCAN, "Passive")
field (DTYP, "stream")
field (INP, "@e5810b_gateway.proto query_idn $(PORT) $(ADDR)")
field (PINI, "YES")
Corresponding stream protocol:
query_idn {
out "*IDN?" LF;
in "%s" LF;
GPIB and serial ports of E5810B are working correctly with EPICS. Also,
the DSOs are responding when they are directly accessed using PyVISA-py
library.
Kindly guide me.
With Regards
Sarthak Gupta
Scientific Officer F
Laser Electronics and Controls Section
Laser Control & Instrumentation Division
Raja Ramanna Center for Advanced Technology
Department of Atomic Energy
Indore (MP) 452013
Ph: +91.731.2488422, +91.731.2442673
- RE: Error in accessing USB based DSO via E5810B Gateway GAGET Alexis via Tech-talk
Memory leak in QSRV/pvAccess server, triggered by incoming UDP search requests (not the known 7.0.10 beacon leak) Adam Piotrowski via Tech-talk
Re: Memory leak in QSRV/pvAccess server, triggered by incoming UDP search requests (not the known 7.0.10 beacon leak) Ralph Lange via Tech-talk
2025
<2026>
2025
<2026>
