1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Memory leak in QSRV/pvAccess server, triggered by incoming UDP search requests (not the known 7.0.10 beacon leak)
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Wed, 16 Sep 2026 13:29:21 +0200
Hi Adam,
This looks like you are using the old (still default) PVAccess software stack.
Can you try running the same test using the new QSRV2 server based on PVXS?
Cheers,
~Ralph
Re: Memory leak in QSRV/pvAccess server, triggered by incoming UDP search requests (not the known 7.0.10 beacon leak) Adam Piotrowski via Tech-talk
Prev: Error in accessing USB based DSO via E5810B Gateway Sarthak Gupta via Tech-talk
Next: WEISS 2.0.0 release André Favoto via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Memory leak in QSRV/pvAccess server, triggered by incoming UDP search requests (not the known 7.0.10 beacon leak) Adam Piotrowski via Tech-talk
Next: Re: Memory leak in QSRV/pvAccess server, triggered by incoming UDP search requests (not the known 7.0.10 beacon leak) Adam Piotrowski via Tech-talk
ANJ, 16 Sep 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
