Thank you for your reply. After switching to the new PVAccess software stack, everything works correctly. Best regads Adam Piotrowski Wiadomość napisana przez Ralph Lange via Tech-talk <tech-talk at aps.anl.gov> w dniu 16 wrz 2026, o godz. 13:29:
Hi Adam,
This looks like you are using the old (still default) PVAccess software stack. Can you try running the same test using the new QSRV2 server based on PVXS?
Cheers, ~Ralph
- Re: Memory leak in QSRV/pvAccess server, triggered by incoming UDP search requests (not the known 7.0.10 beacon leak) Ralph Lange via Tech-talk
- Memory leak in QSRV/pvAccess server, triggered by incoming UDP search requests (not the known 7.0.10 beacon leak) Adam Piotrowski via Tech-talk
WEISS 2.0.0 release André Favoto via Tech-talk
2025
<2026>
2025
<2026>
ANJ, 17 Sep 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
