1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Subject: Re: Support for 64 bit integer Normative Types?
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Fri, 25 Sep 2026 20:01:59 +0200
On Fri, 25 Sept 2026 at 18:19, William Badgett via Tech-talk <tech-talk at aps.anl.gov> wrote:
Is there any plan to create a centrally supported signed or unsigned 64 bit integers as the value field in NTScalar ?
Not sure what you mean; the scalar type in the NT spec contains 64 bit integers.
Cheers,
~Ralph
Support for 64 bit integer Normative Types? William Badgett via Tech-talk
Prev: Re: Same sscan record step size for all positioners not possible? J. Lewis Muir via Tech-talk
Next: Re: Same sscan record step size for all positioners not possible? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026>
Prev: Re: Support for 64 bit integer Normative Types? Sky Brewer via Tech-talk
Next: Fanout with mask - unclear documentation on SHFT Rea Domitrović via Tech-talk
ANJ, 30 Sep 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
