I did what Mr. Rivers said I was able to get the IOC to start with the .dbd file attached but now I cannot attach the .db file. C:\Users\Epics\Documents\Example\iocBoot\iocExample>C:\Users\Epics\Documents\Exa
mple\bin\win32-x86-mingw\test st.cmd #!../../bin/win32-x86-mingw/test.exe ## You may have to change test to something else ## everywhere it appears in this file #< envPaths
macLib: macro TOP is undefined (expanding string cd ${TOP}) ## Register all support components dbLoadDatabase "dbd/test.dbd" filename="../dbLexRoutines.c" line number=243
No such file or directory dbRead opening file dbd/test.dbd test_registerRecordDeviceDriver pdbbase registerRecordDeviceDriver failed aai registerRecordDeviceDriver failed aao registerRecordDeviceDriver failed ai
registerRecordDeviceDriver failed ao registerRecordDeviceDriver failed aSub registerRecordDeviceDriver failed bi registerRecordDeviceDriver failed bo registerRecordDeviceDriver failed calc
registerRecordDeviceDriver failed calcout registerRecordDeviceDriver failed compress registerRecordDeviceDriver failed dfanout registerRecordDeviceDriver failed event registerRecordDeviceDriver failed fanout
registerRecordDeviceDriver failed longin registerRecordDeviceDriver failed longout registerRecordDeviceDriver failed mbbi registerRecordDeviceDriver failed mbbiDirect registerRecordDeviceDriver failed mbbo
registerRecordDeviceDriver failed mbboDirect registerRecordDeviceDriver failed permissive registerRecordDeviceDriver failed sel registerRecordDeviceDriver failed seq registerRecordDeviceDriver failed state
registerRecordDeviceDriver failed stringin registerRecordDeviceDriver failed stringout registerRecordDeviceDriver failed sub registerRecordDeviceDriver failed subArray registerRecordDeviceDriver failed waveform
registerRecordDeviceDriver failed xxx ## Load record instances dbLoadTemplate "db/userHost.substitutions" dbLoadTemplate: error opening sub file db/userHost.substitutions
dbLoadRecords "db/dbExample1.db", "user=EpicsHost" filename="../dbLexRoutines.c" line number=243 No such file or directory dbRead opening file db/dbExample1.db
## Set this to see messages from mySub #var mySubDebug 1 ## Run this to trace the stages of iocInit traceIocInit iocInit will be traced macLib: macro TOP is undefined (expanding string cd ${TOP}/iocBoot/${IOC})
macLib: macro IOC is undefined (expanding string cd ${TOP}/iocBoot/${IOC}) iocInit iocInit: Reached initHookAtIocBuild Starting iocInit checkDatabase: menuConvert not defined.
iocBuild: Aborting, bad database definition (DBD)! ## Start any sequence programs #seq sncExample, "user=EpicsHost" epics> ----------------------------------------------------------------------------- Kind RegardsRusu Vlad Andrei T: (+004)0755.052.954
A: Calea Ferentari 16 Bl.124A Ap.5 Sector 5, Bucharest, Romania 2014-08-28 19:11 GMT+03:00 Mazanec Tomáš <[email protected]>:
ANJ, 17 Dec 2015 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
